OP
son of man
Bronze Member
Thanks for the tips motownebrown! I have a little toolset I've used for years to work on our cars and odd jobs around the house. However, the sizes are just shy of what I need for the tractor. So I may have to bite the bullet and get a nice set. The misses doesn't have a problem buying quality tools or anything else for that matter.
I'm usually the one trying to be a budgeteer. Just this past weekend, she suggested I buy an air compressor for the tractor tires. However, I figured I could 'get her done' with a $10 bicycle pump from Wal-mart. It took a little time but I finally aired up 3 of em before the sun went down. :laughing:
Upon receiving my fuel bowl kit from NCW Tractor Parts, I noticed the fuel filter was significantly smaller than the one I butchered from NAPA. However, once I screwed it on, replaced the bowl, re-poured the spilt diesel and bled the lines, she fired right up! I haven't engaged the PTO yet but I think we're back in business.:thumbsup: However, I am wondering where some of you purchase your fuel filters and how they fit inside the sediment bowl? The one I initially got from NAPA appears to be the same size as the JD filter I replaced.
I admit I had some technical difficulties changing the bush hog oil. The manual recommends SAE 90 or 140. However, I couldn't find either in 1qt bottles. So I bought 2 gallons of Travelers SAE 90 transmission fluid from TSC. It says it was formulated for old Ford tractors but I assume it will work. Since my gearbox only has a check level screw, I bought a little hand pump. I was able to siphon some of the oil but I couldn't get it to flow. Perhaps it was operator error or maybe that's all that was in there? I was also unable to siphon the new oil from the jug into the gearbox. So after a couple of other strategies failed, I grabbed a plastic water bottle, stuck a hole in the cap, inserted a straw and squeezed it until I saw honey brown goodness coming out of the check level hole.
