so, fuel gauge not workin' right, max26
   / so, fuel gauge not workin' right, max26 #1
linuxman51
Montgomery, AL
craftsman lt1000/jd 717a/ mahindra max26 hst
anyone had a float come off the sender? loaded it up the other day to go help a buddy out, and noticed that I was almost in the red. no problem, stop at the gas station and hit'er with the good stuff... after about 3 gallons it started foaming out the top, and was just about overflowing full.
I know for a fact this hog takes more than 3 gallons. haven't had a chance to take a look see down the filler (Reckon I'll do that tomorrow on my day off), but it hasn't been bumped around *that* much.
   / so, fuel gauge not workin' right, max26 #2
did it go to full when you filled it up?
   / so, fuel gauge not workin' right, max26 #3
I usually put 3 gallons in my Max28 when it gets close to the red. After that the gauge usually reads right at the full mark.
I generally only put 3 gallons in my 5 gallon fuel tanks. It makes it easier to hold over the tractor to refuel and keeps from spilling and making a mess.
   / so, fuel gauge not workin' right, max26 #4
At what revs were you working the tractor at?
I've found that my HST tractor's fuel gauge goes 'wonky' at 2500 & above, but it's steady and accurate at 2000. It doesn't matter if I'm in Low or High, it'll red-line whilst working at the higher revs and I know that I've got more than half in the tank.
   / so, fuel gauge not workin' right, max26 #5
My 3016 gauge will be in the red and, if I'm lucky, I can put in 3 gals.
   / so, fuel gauge not workin' right, max26 #6
only a 6gl tank also
DOUBLE!
   / so, fuel gauge not workin' right, max26 #9
Is this what it normally will do?
You said you were loading it on the trailer and noticed it... if your not on level ground or at and angle like that when you check the fuel it wont be right.
Even so.. its not a big deal to replace. one of the easier ones actually
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
HOME MADE SMOKER / FRYER TRAILER (A52472)
HOME MADE SMOKER /...
2022 Mack MD Danco 12R22 22FT Rollback Truck (A50323)
2022 Mack MD Danco...
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A52576)
2013 PETERBILT 386...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A52748)
Koyker Loader...
