Snowplow
   / Snowplow #1
billfires
Southeastern Mass
New Holland 1920
Has anyone mounted a snowplow from a pickup truck onto the loader bucket?I was thinking of mounting the receiver plate ( the part that the plow attatches to on the pickup) onto the back inside of the bucket and use the lift chain attatched to the top of the bucket to support the plow. Does this sound like it would work? Any thoughts, comments or ideas welcomed.
Bill C
   / Snowplow #2
Bill,
With a little yankee ingenuity you shouldn't have any problem. I ran a 7' plow on my FEL all winter. It worked great. I hooked my cutting edge just under the plow ears and up against a piece of angle iron that was already there, locked it all in to place with a strong chain and a chain binder.
This was merely a temporary setup to see if it would work. For next winter I will securely it properly. It was only manual angle and will probably stay that way, but I don't mind.
There are several members on this board that have set up plows in a similar fashion as you would like to do. Attached is a photo of a New Fisher plow installed in a Kubota bucket. This is how my local NH dealer sets them up for people and it is the way I will make mine for this next winter. He sells the bolt in bracket for $150 and I will do the instillation myself adding some reinforcing to the back of the bucket.
Two pins, the lift chain and hydrolics if you have them and the plow will install and remove just like would on a truck.
   / Snowplow #3
Here is a closer shot of the bracket. I think it is pretty slick and simple.
   / Snowplow #4
Does the dealer install new hydraulics for the plow or just use existing ones from the FEL?
   / Snowplow
Mark, thank you, that is exactly what I was thinking about. With the mild winter we have had i am pretty sure I can pick up a used blade for short money. Thanks again.
Bill C
   / Snowplow #6
Mike,
I would think and expect that if necessary, and if the machine owner wanted them,the dealer would install additional hydrolics.
On the machine I saw there last fall (not the one pictured earlier) they ran hoses back to the rear hydrolic fittings. I have attached a picture of that tractor.
It was also a Kubota (a big one w/ full cab) I believe that this one was theres and used to plow there yard. It doesn't show the hoses real well, but I remember them running down the side of the machine and into the rear connections.
   / Snowplow
Mark, I have been looking in the "Want Advertiser" and there seems to be a few plow blades only for sale. I need to determine the size plow. I am thinking a 7 1/2 foot Meyers would work and by dropping the BH I could use the rear remote for the power angling. Thanks for the info.
Bill C
   / Snowplow #9
Mark,
If I may . . .
You're in New Hampshire, so I take it you get a good bit of snow. The JD 950 is 27 (or so) hp, correct?
I'm moving to Vermont in Summer '03 and have a 1500' drive to move snow off of. I've been trying to determine my hp and other needs so I buy enough tractor. My research up till now suggested that your rig would be underpowered, but I may be mistaken.
How much do you plow? How high do your walls of snow get? How fast does your setup handle the job?
I'd love to save the $3-4000 and not buy a snowblower if I don't need one.
Thanks,
   / Snowplow #10
Marc,
I will try to answer your questions as best as possible. Normally New Hampshire gets a great deal of snow, this year has been a very marginal year snow wise.
I am actually the last person you want advice and knowledge from on what size and HP tractor to do ??? jobs.
Although I grew up on a small working farm doing haying, plowing, harrowing, firewood etc. and have been around tractors most all my 40 yrs. This is the first tractor that I have ever owned and I have only owned it for 1 year.
It is also the first year I have EVER plowed snow with ANYTHING !! But, I am pleased to say that my 950 MFWD with 27 HP (per manual) and turf tires has performed flawlesly in keeping my yard clean.
I have attached a picture of my yard taken from my neighbors driveway, unfortunatly there is no place where I can stand to get a picture of the Whole driveway and yard, but the pic will give you an idea of what I plow.
My driveway continues off to my left up to the main road, probably another 300', as you can see my driveway is actually a big tear drop with a good size parking area. I hate snow banks, So where possible I push the snow all the way to the tree line.
With the front blade, it probably takes me 2 hours to plow and clean up the way I like it. 1- I am in no hurry (seat time), 2- I am a fussy SOB. A friend once told me that they could use my yard for Super Bowl overflow parking.
I personally don't see the need of owning a snowblower for what I do. My front blade does an excellant job.
I am positive that there are other members here that are more knowledged and can help you in determining what size tractor would be best suited for your needs, for I am sure that plowing snow is only one of many jobs you will be wanting your tractor to do.
27 horse power with 4wd and proper weight will surprise the heck out of you with what it's capable of doing.
I hope this has helped and not just confused you or put you to sleep.
2017 HINO BOX TRUCK (A53426)
2017 HINO BOX...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
1985 Miller Wildcat 350-D Welder (A51691)
1985 Miller...
Pallet of Crafco Asphalt Sealant  (A52384)
Pallet of Crafco...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2004 FORD E350 MECHANICS TRUCK (A53426)
2004 FORD E350...
