SNOWPLOW L3010
   / SNOWPLOW L3010
My valve is L2207 ,that does have the float function.Power down is also very nice for hard packed snow. I also mentioned,that I bought Kubota Q/D to fit the valve. I did this so that I would be able to switch between plow and loader without difficulty.(male end stays on the valve). Angle cylinders are 1-way,as you power one,the control valve lets the hydraulic fluid from the other bleed out. /forums/images/graemlins/confused.gif
   / SNOWPLOW L3010
Also forgot to mention,predrill everything that you possibly can off of the tractor,especially the loader x-member. On it,simply remove four bolts.Drill x-member,and rear angle iron and bolt them together off the tractor.Also weld up the stop piece to the front of the rear angle iron,this will make for perfect alignment. Also drill the rear angle iron holes slightly oversize for whatever size bolts you use.(I used 1/2" grd5).This will aid in installing and removing.Front and rear mountings were bolted into place ,stringers (2"sq. stock) were held up into position and tack welded in place.Whole sub-frame was then removed and finish welded.
   / SNOWPLOW L3010 #23
" <font color="red"> </font> " Good point! It would not be easy at all trying to drill that steel from under the tractor- Thanks again!
   / SNOWPLOW L3010 #24
botaman2 ... Hello from Okeechobee, Fla /forums/images/graemlins/cool.gif
Although I'm not in NE for the winter, it sure is nice to know you're keeping everything well plowed at your place as usual /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Best regards to you and your BOTA. /forums/images/graemlins/wink.gif ...RayBee
2012 GMC Savana 3500 Passenger Van (A55852)
2012 GMC Savana...
2016 Chevrolet Traverse SUV (A55853)
2016 Chevrolet...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
Honda EU3000is Gasoline Companion Inverter Generators (A55851)
Honda EU3000is...
SOMERO S-222 LASER SCREED (A52707)
SOMERO S-222 LASER...
