Snowplow front bucket replacement
/ Snowplow front bucket replacement #1
jnporcello
South of Buffalo, NY
John Deere 4600
Here are some pictures from a snowplow attachment that was made this time last year. I don't have the photos, but the back side has the 3/4 round at the top and round stock on the bottom so that all that needs to be done is remove 2 pins and then the bucket off of the loader. Then the back plate for the plow just slides on and replaces the bucket and I made 2 hydraulic lines that plug into the bucket roll quick connects -- this gives me left and right plow angle instead of up and down bucket curl. Whole thing pops on and off in under a minute.
/ Snowplow front bucket replacement #2
Nice job converting the old ST Meyer plow for use on your loader. I'm hoping to do the same when I find a suitable old snowplow. Putting skid shoes on your mounting plate is a clever way to get the back end of the a-frame at the proper height.
/ Snowplow front bucket replacement #3
Awesome, but it makes me nervous with all that force being applied to the loader arms. Its just so far out front, and has alot of leverage.
I bet it works great! :thumbsup:
/ Snowplow front bucket replacement #5
I connected my Western plow in a similar manner. Works great and has for about 10 years now.
Bucket curl circuit runs right and left angle, and FEL lift/down-float operates the single acting lift cylinder.
Custom made the quick hitch to the front frame.
/ Snowplow front bucket replacement #6
How do those hydraulics work with no return line :confused:
Each SA (single acting) cylinder is hooked to the valve...the valve will see the two SA cylinders as one DA (dual acting) cylinder. No problems unless the valve has a regen (regenerative) function that can't be turned off.
/ Snowplow front bucket replacement #7
Nice neat clean job,shall be looking forward to action pics soon.
/ Snowplow front bucket replacement #8
Good note mentioned by kennyd, as the regen feature (pushing joy stick full right) will stop the angle function. On my JD 4300, pushing stick part way to the right is necessary to avoid the regen feature to operate the single acting cyl.
I actually put them on there so I could use the float position of the loader. Without them I would have had to keep the backplate just off the ground and adjust continuously. This way I can put it down and into float and just go.
/ Snowplow front bucket replacement #10
I doubt you'll want to float the whole loader and blade. That's a lot of weight dragging and ends up putting more stress on the loader arms as well as sinking the shoes into any soft or loose ground. You have the chain on the blade so you can take advantage of that by tipping the blade (dump) forward and raising the loader a few inches. This keeps the loader wheight off the ground but still allows your blade to float on it's own.
This has been my experience anyway, and keeping the loader slightly raised with only the blade floating lets me move snow much easier.
2003 Proclaim Tanker Trailer (A64194)
2003 Proclaim...
Barrel (A64557)
Barrel (A64557)
2007 Chevrolet Silverado 3500 4x4 Service Truck (A64556)
2007 Chevrolet...
MECHANICAL 4R48" FINGER TYPE SETTER (A64278)
MECHANICAL 4R48"...
2020 CATERPILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A65053)
2020 CATERPILLAR...
2018 Chevrolet Tahoe SUV (A64557)
2018 Chevrolet...
