snowplow and rear weight
   / snowplow and rear weight
Hi Brad,
You aren't that far from me. Son lives over in Corinth soooooo I'm over there once and a while. Find there are many tractor owners in the area.
/forums/images/graemlins/grin.gif
   / snowplow and rear weight #22
Deerlope
I attended SUNY starting in 1980 majoring in geology. Great group of professors in the geo dept. Some friends and I used to have a good time small game hunting up there as well as fishing along the St. Lawrance and Raquette rivers.
Brad
   / snowplow and rear weight #23
I have a L3010HST with a 6.5'Myers plow. For rear weight I have 600#on 3ph,plus loaded rear tires. This will be my third winter of plowing,so far I haven't had anything I couln't push.I'am not sure of the plow weight,probably around 250#,plus sub-frame around 70#.I generally plow in float position,however if the ground is not frozen,I raise the plow up a little.I also have down pressure to scrape the paved section clean.I always plow in 4wd.
UNUSED PABREAK TCR380-84" HYD TILLER (A57193)
UNUSED PABREAK...
2002 6ft. BushHog Rotary Brush Cutter Tractor Attachment (A55851)
2002 6ft. BushHog...
CATERPILLAR HYD HAMMER (A52707)
CATERPILLAR HYD...
2022 Polaris Ranger Utility Cart (A55787)
2022 Polaris...
Bush Hog 7007 3pt Grader Blade (A53317)
Bush Hog 7007 3pt...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52707)
KNOW BEFORE YOU...
