Snowower bearings grease type?
   / Snowower bearings grease type? #1
Max2310
Canada (QC)
GC2310 2008
I finally got my snowblower and there are grease fittings all over the place. My blower did not came with a user manual and I was wondering if lithium base grease is good for bearings?
Ya, I noticed my nice title, too bad I can't fix this.
Thanks in advance!
   / Snowower bearings grease type? #2
I checked out my Kubota snow blower manual and it didn't specifiy a type of grease. It says to grease it every 8 hours.
Link
Thanks for looking!
I was about to start another thread (using a diferent title) since I'm not getting much feed-back with this one. I thing people are afraid to open a thread from someone who can't spell snow blower :eek:
thanks smfcpacfp, I'm sure someone will eventually have an answer for me...
So far, lithium it will be!
   / Snowower bearings grease type? #4
The Moly-disulfide grease(the black stuff like the CV axles use)is an excellent choice.Moly EP.I've seen it in Kubota dealers in the Kubota brand at the dealer.Valvoline/NAPA/Carquest also has it as well as others.Best stuff other than Lucas or synthetic-pennies more then lithium.Used for 30 yrs with great results.Good luck!
   / Snowower bearings grease type? #5
I've been using Texaco Starplex-2 grease, but last time I was at a Tractor Supply store I got their Traveller Premium Truck and Tractor grease. The Texaco states that it's lithium-based, TSC's says "Formula Trade Secret", whatever that means.:confused:
Both are rated GC-LB. On the blower chain, I use Honda motorcycle chain lube.
   / Snowower bearings grease type? #6
Any grease is better than no grease. Overthinking the lubrication of implements such as a snowblower is easy to do. Buy grease where it is convenient to buy, and use it as required. Usually every 8 hours or so of running time. In this type of application, "better" grease isn't better enough to debate or worry about.
   / Snowower bearings grease type? #7
I agree, about the only special thing I would look for would be that the grease is resistant to washout, given the application. If you are diligent about greasing every 8 hours even that would not be a great concern. Not like any of the greased parts should ever get more than warm.
   / Snowower bearings grease type? #8
And to complicate life a little more ...... the manuals caution not to over grease those fittings on bearings
because the seals will "push out of location".
So I guess a little bit ... everywhere ...often.
   / Snowower bearings grease type? #9
Flamingo Maxima EP.PDF file on it. Won't wash out. In fact, it's a pain to get out of bearings once used as even Zep parts cleaner fluid doesn't cut it.
Maxima: "Made in the Tropics for the Tropics." Thats the first sentence written in the PDF. :confused: Could be good for summer use but I hate moving snow when its just too hot.
Nice try ;) Thanks anyway :)
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
2017 FOREST RIVER 20 T/A CARGO TRAILER (A53843)
2017 FOREST RIVER...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
