Snowower bearings grease type?
   / Snowower bearings grease type? #1
Max2310
Canada (QC)
GC2310 2008
I finally got my snowblower and there are grease fittings all over the place. My blower did not came with a user manual and I was wondering if lithium base grease is good for bearings?
Ya, I noticed my nice title, too bad I can't fix this.
Thanks in advance!
   / Snowower bearings grease type? #2
I checked out my Kubota snow blower manual and it didn't specifiy a type of grease. It says to grease it every 8 hours.
Link
Thanks for looking!
I was about to start another thread (using a diferent title) since I'm not getting much feed-back with this one. I thing people are afraid to open a thread from someone who can't spell snow blower :eek:
thanks smfcpacfp, I'm sure someone will eventually have an answer for me...
So far, lithium it will be!
   / Snowower bearings grease type? #4
The Moly-disulfide grease(the black stuff like the CV axles use)is an excellent choice.Moly EP.I've seen it in Kubota dealers in the Kubota brand at the dealer.Valvoline/NAPA/Carquest also has it as well as others.Best stuff other than Lucas or synthetic-pennies more then lithium.Used for 30 yrs with great results.Good luck!
   / Snowower bearings grease type? #5
I've been using Texaco Starplex-2 grease, but last time I was at a Tractor Supply store I got their Traveller Premium Truck and Tractor grease. The Texaco states that it's lithium-based, TSC's says "Formula Trade Secret", whatever that means.:confused:
Both are rated GC-LB. On the blower chain, I use Honda motorcycle chain lube.
   / Snowower bearings grease type? #6
Any grease is better than no grease. Overthinking the lubrication of implements such as a snowblower is easy to do. Buy grease where it is convenient to buy, and use it as required. Usually every 8 hours or so of running time. In this type of application, "better" grease isn't better enough to debate or worry about.
   / Snowower bearings grease type? #7
I agree, about the only special thing I would look for would be that the grease is resistant to washout, given the application. If you are diligent about greasing every 8 hours even that would not be a great concern. Not like any of the greased parts should ever get more than warm.
   / Snowower bearings grease type? #8
And to complicate life a little more ...... the manuals caution not to over grease those fittings on bearings
because the seals will "push out of location".
So I guess a little bit ... everywhere ...often.
   / Snowower bearings grease type? #9
Flamingo Maxima EP.PDF file on it. Won't wash out. In fact, it's a pain to get out of bearings once used as even Zep parts cleaner fluid doesn't cut it.
Maxima: "Made in the Tropics for the Tropics." Thats the first sentence written in the PDF. :confused: Could be good for summer use but I hate moving snow when its just too hot.
Nice try ;) Thanks anyway :)
2005 International 4300 Telsta Telescopic Bucket Truck (A52377)
2005 International...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
SCAN FOR HAULING AND FINANCING INFORMATION (A52705)
SCAN FOR HAULING...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
More info coming soon! (A50322)
More info coming...
