snowblowing
   / snowblowing #1
haroldy
near peterborough,ontario
kioti ck30,,front mount snowblower
Snowblowing
11 times this year
Just finished 2 hours blowing 8 inches of new snow with CK30 e/w 6ft front snowblower
Everything worked great
I do 1 km of laneway plus 9 driveways on a private road
last fall I replaced my MF 1020 with a front snowblower I had used for 22 years on the same road..and thought it was time to move on
   / snowblowing
yes , I made a simple cab just before the first snow. 6 mil lexan on wood frame , same as I had on mf1020,, it lasted 23 years and I remove it in spring
the blower and front mount apparatus is mk martin
come summer I plan on grooving r4 tires for better traction
   / snowblowing #4
I've got a Martin, too. I'm not overly impressed with how far it throws the snow. I am a little northwest of you, just south of North Bay.
   / snowblowing
1510728_648294938546283_1957698960_n.jpg how many rpms are you running,,mine seems to work fine
   / snowblowing #6
I take the tack up to 2400 r's. That is just below the red triangle for the rear PTO. I tried last spring to take off the front tranny, (the one that hangs down below the grill) and turn it around. When I went to put in the bolts, all the holes were gone. So this summer I am going to make an adapter plate and weld that in place and put the tranny on backwards to see if that helps.
   / snowblowing
standard tires the way it comes for 2013 model ck 30 hst,,
,didnt realize the clearance until you mentioned
   / snowblowing #9
I've only got about 2.5-3" of clearance between my fenders and tires with my R-4's. I am seriously thinking of a lift kit to get some more clearance so I can run chains on the rears.
You wouldn't be in Norwood would you?
   / snowblowing
No just n/e of peterborough at youngs point
I assume you have r4 s
I had turf on my mf 1020 and found them to be the best for snow and ice ..thats why i am going to groove tires next summer
from what i have read it sounds good
norwood ???? you from there
(APPROX 250) UNUSED TRAFFIC CONES (A51248)
(APPROX 250)...
2017 UTILITY VS2RA 53FT REEFER TRAILER (A53426)
2017 UTILITY VS2RA...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51248)
(2) METAL SPOOLS...
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
