Snowblowing RPM
/ Snowblowing RPM #1
rScotty
Super Member
Rural mountains - Colorado
Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
How fast do you have to run your Kubota's engine to blow snow? From videos it seems like some of them are really cranked up! Does that wear the engine? Any problems? Noise?
Spinning a tractor motor at high revs for hours on end would be a big difference for me. Mostly I'm not running the PTO, so we just run with enough throttle so that it will get up to speed and temperature and fast enough that a sudden load won't lug it. With HST and autothrottle the tractor sets that automatically at somewhat more than a fast idle......probably more revs than it needs, but the autothrottle is being conservative and at least is nowhere near wide open. Even so, the autothrottle sometimes revs it more than is needful for conditions.....ike blading or pushing a little snow on the level. In that case I run quite a bit of the time with the autothrottle off.
Of course that's just for loader and backhoe work. Anytime I load the PTO up then I'll go ahead and crank it up closer to full rated RPM. Snowblowing looks like one of those times, but I don't have a blower yet and thought I'd ask how others are running theirs.
rScotty
/ Snowblowing RPM #2
I run mine at the pto speed according to the little triangle (2550 rpm) on the tack. For loader work and running down the road I go with 2200rpm.
/ Snowblowing RPM #3
For front end loader work I run at a speed which lets me spin all four tires if I need to. Usually around 3/4 throttle. Any pto equipment gets run at full throttle. There are times I don't need all the power but I like to keep equipment like a rough cut mower running at top speed. Rototilling I need all the power I can get so It gets full throttle. I can control engine speed by how fast I go using a hydrostatic transmission. Snow blowing I don't need the power but I sure like the fact that if run at full throttle the snow blows further away. Full throttle on my tractor is about two hundred rpm over pto speed.
/ Snowblowing RPM #4
I live in a snow belt. A foot of snow is a fairly common occurrence. When blowing snow, I run the engine between 1800 to 2000 rpm's. If the snow is a couple of feet, which doesn't happen very often, I might bump the rpm's up a bit to 2200.
/ Snowblowing RPM #5
On my B2620 I run the rpms at 2,000 or higher. Lugging the engine at low rpms is bad and will clog it up the blower as well.
/ Snowblowing RPM #6
I run engine speed to get rated pto speed. That is where engine and equipment are designed to run for ideal performance. You cannot over rev these little engines, they are controlled by their governor to keep speed in safe operating range. Most of us do not use theses tractors enough to wear out the engine. Philip.
/ Snowblowing RPM #7
I'll occasionally run the full 540 pto (eng 2600 rpm) if needed, for deep snow, heavy wet snow or I need to throw the snow an increased distance.
Normally I'm run at 2000 eng. rpm.
/ Snowblowing RPM #8
It depends on the snow. I have a 3 point mounted blower so I usually use the 900 rpm gearing on my PTO and set the engine at 1750 to get 540 rpm at the blower. If the snow is really deep and/or wet I use the 540 rpm gearing and run the engine up to 2550 for more power.
/ Snowblowing RPM #10
For me I run the engine to get the rated 540 rpm from the 3 pointed mounted blower, being do it now for 5 years and in that time we have had a lot of snow, no problems yet. (knock on wood) I make sure that I do the regular maintenance, engine oil and filter. I agree with Philip8N its what the engine was designed to do. I think its better than lugging your engine.
/ Snowblowing RPM
That makes sense to me. It sure is nice to have HST isn't it? After having the old fashioned gear driven tractors all my life it is a real treat to have a HST machine where the driving is separated from the PTO work. With HST we can run the engine as fast or slow as it needs to work the PTO without the engine speed affecting the way the tractor drives at all. It's a whole new way of running a tractor.
And the autothrottle makes it even better. Now I can just putz along at an idle enjoying the work and daydreaming. And feeling secure in the knowledge that if the machine needs more throttle or RPM it will make it happen automatically and without any input from me. All I have to do is steer. Now if only it came with a cab, a reclining seat, and dual drink holders.....
rScotty
/ Snowblowing RPM #12
That makes sense to me. It sure is nice to have HST isn't it? After having the old fashioned gear driven tractors all my life it is a real treat to have a HST machine where the driving is separated from the PTO work. With HST we can run the engine as fast or slow as it needs to work the PTO without the engine speed affecting the way the tractor drives at all. It's a whole new way of running a tractor. And the autothrottle makes it even better. Now I can just putz along at an idle enjoying the work and daydreaming. And feeling secure in the knowledge that if the machine needs more throttle or RPM it will make it happen automatically and without any input from me. All I have to do is steer. Now if only it came with a cab, a reclining seat, and dual drink holders..... rScotty
Pto speed on my b2920! The reason is two fold
Allows HST to operate properly
Torque curve is highest just off Pto speed so that when rpm's start dropping it hits its highest torque rating bumping rpm's back up.
Makes a huge difference in ability to clear snow quickly and not have it pile up in front of the blower.
Sent from my iPhone 5s 64Gb using TractorByNet
/ Snowblowing RPM #14
rScotty
Don't forget the remote control!:laughing:
/ Snowblowing RPM #15
I have auto-throttle and HST, personally, I would not use auto-throttle with PTO engaged equipment. Philip.
/ Snowblowing RPM #16
540 RPM pto speed takes 2150 engine RPM on my tractor. Whether its the wood chipper or the snow blower I always run at 540 RPM pto speed.
/ Snowblowing RPM #17
A snowblower hooked to a 540 rpm pto is meant to run at 540 rpm. There may be times when you don't need it running full blast because there isn't that much snow or you don't need to throw it quite as far. But both the blower and the tractor are designed to be ready to do so when they need to. As for engine wear, I believe the engines are designed to do so also. Ag tractors run for 12-16 hours a day, day after day, pulling heavy loads under a variety of circumstances: seedbed preparation, planting, chemical application, fall tillage, etc. Every farmer I know has the throttle pulled wide open to do so. A couple hours on the snowblower won't compare to that.
/ Snowblowing RPM #18
BX25 with a BX2750D on front. I run WOT and have for 4 years. These engines are made to run WOT. That's why you find Kubota engines in wood chippers. I checked the 2750D manual and it says something like, "...when you need more power run wide open throttle."
/ Snowblowing RPM #19
/ Snowblowing RPM #20
With anything diesel WOT is the way to go. They are designed just for that.
With good oil at WOT your tractor will never see an engine overhaul during your lifetime.
WOT is where the power curve is at its best setting.
