Snow Snowblower
/ Snowblower #1
dave1132
When attaching rear snowblower how should the skid shoes b on the ground or a little off ground? Also I assume it must b level
/ Snowblower #2
What type of surface are you blowing? If its gravel you need to have the skid shoes set so that the scraper edge off the ground enough so that you don't pickup stones. Pavement you can have the scraper right to the ground. Hope this helps ya out. I have mine set to be 1/2 -1" off the ground for my gravel driveway.
/ Snowblower #3
Yes you want it setting level. The ski shoe heighth varys. If you have a gravel drive you will want the cutting edge off the ground so you are not throwing rocks. Put the blower on the tractor and try dropping the blower in different places (prefeeably in uneven spots)and get off the tractor to see if cutting edge will touch the ground, if it does raise it a notch.
/ Snowblower #4
Some people say, once ground is frozen, you can take skids off. I'm ready.
2018 CATERPILLAR 303E CR EXCAVATOR (A65053)
2018 CATERPILLAR...
2015 FORD F350 XL SUPER DUTY BUCKET TRUCK (A63276)
2015 FORD F350 XL...
2009 MAC 35ft. 75yd. Tri-Axle Aluminum End Dump Trailer (A64556)
2009 MAC 35ft...
2007 International CE200 School Bus (A64194)
2007 International...
2025 LandHonor LHR-DFP10 Diesel Fuel Transfer Pump (A64194)
2025 LandHonor...
2017 Bad Boy Outlaw XP 60in. Zero Turn Commercial Mower (A64553)
2017 Bad Boy...
