Snowblower Snowblower powered by tractor's onboard hydraulics
   / Snowblower powered by tractor's onboard hydraulics #11
Re: Snowblower powered by tractor\'s onboard hydraulics
Hydraulic motor formulas:
Torque (in*lbs) = (PSI) * (Displacement (in^3/rev))
(2 * pi)
HP = Torque (inch*lbs)*RPM)
63025
RPM = (231*GPM)
Displacement of motor in^3 per revolution
Displacement of motor in^3 per revolution = (231*GPM)
RPM
HP = gpm*psi
1714
All the lines were erased when I copy/pasted this. Each equation has the numerator as the first line, the denominator as the second.
Hydraulic Supermarket Technical pages have a wealth of information.
   / Snowblower powered by tractor's onboard hydraulics #12
I checked into this a few years back. I also checked into a brush/broom to fit on my loader. In both instances I ran into a glitch as there is great concern for heat. Now with the snow blower and cold weather maybe not a concern, but I would still take it into my thinking or decision. Our coolers on our tractors just aren't big enough for moving that much oil.
murph
   / Snowblower powered by tractor's onboard hydraulics #13
OK, I agree in theory, 90% at the moter times 90% at the pump is closer to 80%. Throw in some control valves, some hoses, an oil cooler, and a filter, and you go down a bit more from that. Size the hoses right, and they are not a big factor. Use a large enough filter, and high enough flow valves, and they are not an issue either. (maybe no valves in this applicaiton - just start and stop the PTO).
My 60% for the entire system is a very conservative number that should be easy to hit.
" ... A reservoir is connected to the 3 point hitch. Usually a reservoir the size of the GPM rating of the pump is used but a larger reservoir helps to dissipate heat. ..."
For a continuous duty applicaiton with just a pump and a motor, you might be better off with an oil cooler and fan vs. the larger tank and the fluid to fill it.
- Rick
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2015 MACK ELITE...
UNUSED FUTURE MINI SKID STEER HYD 4IN1 BUCKET (A51244)
UNUSED FUTURE MINI...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
2010 Honda accord (A50324)
2010 Honda accord...
Case IH 7120 Combine (A50514)
Case IH 7120...
2014 CATERPILLAR 272D XHP WHEELED SKID STEER (A51242)
2014 CATERPILLAR...
