Snow Snowblower for 2015HST
/ Snowblower for 2015HST #1
hockeymaine
Any recommendations for a snowblower for the 2015 HST? I have long driveway with a wall. It is slow with front end loader. Any idea on cost also?
/ Snowblower for 2015HST #2
A 3 pt. blower would work well for your driveway with a wall. Just go slow when backing into heavy snow. Backing too fast into heavy snow is a good way to bust a shear pin either on the blower or PTO shafts. A 3 pt. blower should be at least as wide or slightly wider than your rear tracks. My 2615HST is 59" wide and I use a 64" wide PUMA blower. I mainly use the loader in float and just push like a plow then lift and dump, turn around and go the other way, lift and dump. The first half of our snow season I plow with the loader and only use the blower as rear weight. From middle to end of season I may or may not use the blower. It depends on how much snow we get at the time.
There are many good brands of blowers. I'd say new 3 pt. blowers in the size you need would range from $1200-1800. I don't know if there is a front mount blower made to fit the 2015 but front mount units are more expensive.
I got a price of $1500 for a Meteor 51". Anyone have experience with this brand? Price seems in line to me.
/ Snowblower for 2015HST #4
I used a 51" meteor this year. Once I lined it with UWMW polyethylene, it hasn't clogged at all even with wet snow. I'm very pleased with it, especially since I found it locally on ebay used for a little more than a third of the price you found. New, a local dealer wanted nearly $1700. My yanmar tractor is 15HP, an did OK with it, but a little more HP would be a plus.
If you search for 51" meteor, you'll find a thread about how I added the PE.
/ Snowblower for 2015HST #6
Hockeymaine,
Here's a couple more pictures of the meteor in action. I really like the loader, rear blower combination with the little yanmar and fairly short driveway.
Hi Galen,
I actually took a drive out your way last weekend because I was curious to see a Mahindra up close. The place was closed, so I meandered around back to see what implements you have and saw your meteor. It's in much better shape than mine. It looks like a newer model with a bit smaller chute. I saw some larger Mahindras. Do you also sell the smaller units like the 2015?
Craig
/ Snowblower for 2015HST #7
Craig
Yes I handle the smaller ones. I just recieved a shipment that had a 1815 HST w/loader a 2015 HST w/loader a 2415 HST w/loader and a 4530 w/SKC loader. I hope to move them out quickly and get in another shipment. I'm glad to here you stopped out. I'm sorry things were in a bit of disaray but when this snow goes away I will get things in better order. Stop out again when you get a chance. I most generally am open on Saturdays from 9:00 to 3:00. And can also make evening and Sunday appointments. Take care.
Fendt FT500 Tractor Light Kit (A63117)
Fendt FT500...
RoGator and Terragator Manuals (A63117)
RoGator and...
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A64194)
2014 Ram 2500 4x4...
2018 Infiniti Q60 AWD Coupe (A61574)
2018 Infiniti Q60...
1998 Freightliner MT45 Step Van Food Truck (A61573)
1998 Freightliner...
UNUSED IRLMC DELUXE MASSAGE CHAIR (A64281)
UNUSED IRLMC...
