Snowblower chute rotation chain icing up
   / Snowblower chute rotation chain icing up #11
OK, good to know-- I guess snow doesn't stick to it enough to bother!
Thanks for letting us in on your solution.:thumbsup:
   / Snowblower chute rotation chain icing up #12
I spray my snowblower with Fluid Film, and I mean I spray the whole thing. The stuff works.
   / Snowblower chute rotation chain icing up #13
I coat the chain on mine with grease. Never had a problem with it not turning. I try to clean the snow off the entire unit (including the chute area) with an ice scraper after each use it.
dsb
I still battle the chute rotation chain ice up, a bit less than before. Best seems to be to grease the chain and chute surface where the chain contacts the chute, lasts about two days. 2nd best is to use chainsaw bar oil on the chain and chute surface, lasts about one day. Last place is the spray on chain lube, lasts about four hours, also the easiest to apply. I always clean and remove any ice buildup before parking the machine.
KEWANCE 200 9' GRADER BLADE (A57192)
KEWANCE 200 9'...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2022 Chevrolet Silverado LTD (A56858)
2022 Chevrolet...
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A56858)
2018 Nissan Titan...
3419 (A57193)
3419 (A57193)
PALLET OF NYLON SLINGS, METAL TOOLBOX W/ CHAINS (A54757)
PALLET OF NYLON...
