Snowblower Snowblower chain lube
   / Snowblower chain lube #1
smokydune
I saw motorcycle chain lube as being a good lube for snowblower drive chains. Something that will not sling off at max. R.P.M. Tonight I tried chainsaw bar oil. After an hour of blowing I found an acceptable amount of lube on the chain. This was much better than the waterproof snowmobile grease I had been using and was a fraction of the price. I will have to apply every other time though. smoky
After posting above, I took note of the difference between bar lube and chain lube. Chain lube seems to be a better product, but I have not tried it yet. I will purchase a can at Napa and give it a try. I'll then post my results. smoky
   / Snowblower chain lube #3
Smoky,
I've been using chainsaw bar oil on my BX2750 blower chain for 5 years now and have never had a problem. I have an old pump oil that I use exclusively for the blower and I have that filled with the bar oil. I pump some oil down on to the top of the chain while it's rotating to get good penetration. I do that through a vent hole in the top of the chain guard...it saves me pulling off the guard housing. I don't see a lot of the oil getting slung around, but don't mind if it does. Dyer, retired
   / Snowblower chain lube #4
Make up a wick oiler system or a bump or jiggle drip oiler... worked on the oldies..
soundguy
UNUSED FUTURE QUICK ATTACH PLATE GRABBER (A51244)
UNUSED FUTURE...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A50046)
2018 FREIGHTLINER...
71067 (A49346)
71067 (A49346)
UNUSED AGT KRW23 WHEEL LOADER (A51243)
UNUSED AGT KRW23...
John Deer 625F Grain Platform (A50514)
John Deer 625F...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
