Snowblower Snowblower Auger Chain Lube
   / Snowblower Auger Chain Lube #1
GoodGuy
Nova Scotia, Canada
JD 4210 E-Hydro
On my 6 foot PTO Snowblower, I'm not comfortable with how to keep the auger chain lubed properly because it seems because it's exposed, the snow washes the lubrication off. When I'm done blowing & look at the chain it is very shiny which indicates metal on metal wear. Is this something I need to be concerned with? I notice that some models have the chain enclosed and wonder if that really helps. It would seem that any kind of lube would get washed off no matter the type. Any ideas or thoughts?
   / Snowblower Auger Chain Lube #3
I just spray some Fluid Film on mine when I finish cleaning off the snow. Mine is open like yours -- has not seemed to be an issue:eek:
   / Snowblower Auger Chain Lube #4
I think you would be happy if you were to try a can of Fluid Film. It won't wash off and you can spray the whole unit with it. great stuff!! fluid-film.com
Check out the forum at plowsite.com
   / Snowblower Auger Chain Lube #5
studor, you must have posted as I was typing mine. great minds think alike
   / Snowblower Auger Chain Lube #6
I have used motor oil and winter chain lube. I just add oil after every use. My blower is around 12 years old with original chain.
   / Snowblower Auger Chain Lube #7
I don't think it's a big deal but I slap some grease on it now and then just because it doesn't hurt. Figure the grease clings a little better.
   / Snowblower Auger Chain Lube #8
I oil mine up each spring, when I paint her up and get her ready for the following winter. As long as you keep it from getting rusted up....you could probably pee on it an it would still last 50 years....
   / Snowblower Auger Chain Lube #9
10+ year old 7' snow blower, original chain: every spring I grease the heck out of it, every 3-4 snow storms I hit it with some chain saw bar oil. It's tacky and stays put. The blower is inside in the winter and stored outside the other 3 seasons.
Miller Welder (A51691)
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2023 CATERPILLAR 299D3 SKID STEER (A51242)
2023 CATERPILLAR...
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
2023 JOHN DEERE 317G SKID STEER (A51242)
2023 JOHN DEERE...
TRAILER AXLE (A51244)
