Snowblower at both ends?
   / Snowblower at both ends? #1
Boyd W
Case 448
Is there any tractor made that can be operated with snowblower attachments at each end?
   / Snowblower at both ends? #2
My little JD2305 has a selector to operate the mid-pto and rear pto simultaneously. Conceivably, you could mount both front and rear snowblowers. I wouldn't think that it would be a very cost effective method for snow removal.,,
   / Snowblower at both ends? #3
My Massey is the same. Both PTO's can be operated at the same time.
   / Snowblower at both ends? #4
Although I can see snowblowers installed on both ends of the tractor, I'm kind of curious if Boyd W intends to blow snow in both a forward and reverse gears...or if he intends to put a pull behind blower on the rear PTO.
   / Snowblower at both ends? #5
Even then the rear would need to be offset or there would be nothing to blow.
   / Snowblower at both ends? #6
Yeah...except for a bit missed by the front blower.
But using snow blowers in both forward and reverse doesn't seem too efficient either...that's not even factoring in the costs of two blowers.
   / Snowblower at both ends? #7
It could be done by a few tractors with mid PTO's, like Deere, BX & B & Grand L Kubota but I wonder for what reason as Roy said it well it would not be cost effective.Not unless you have $$ to burn.
DevilDog
   / Snowblower at both ends? #8
Most all newer subcompacts can use both ptos. This is often to power a MMM and rear grass collector. However I do not see any reason to run two snowblowers. Snowblower & bllade combo is a more common approach.
   / Snowblower at both ends? #9
Why would you need both pto's at the same time?
I could see where blowers on both ends could be practical for certain applications, maybe commercial snow removal in tight parking areas with very heavy snow accumulation, like a condo complex, where there may be little room for maneuvering. but it would be blowing forward or blowing backward, not both at one time.
Cost wouldn't be a factor for commercial use, but I agree it would be impractical for private use.
JB
   / Snowblower at both ends? #10
DevilDog
Even with dollars to "blow" ???? Just like disc mowers in hay they have front and rear mount but one has to be offset. Actually they have a front mount and 2 rear mounts ... the rear mounts are offset left and right. Or am I missing something here???
2019 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4X4 - 72258 miles -Altec AT40G Boom (A53472)
2019 Ford F550...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
WESSEX CHT-100R-E LOT NUMBER 237 (A53084)
WESSEX CHT-100R-E...
2013 Chevrolet Malibu Sedan (A51694)
2013 Chevrolet...
LMC LOT NUMBER 142 (A53084)
LMC LOT NUMBER 142...
2019 RAM 3500 (A52472)
