Snow Pusher Size for JD 5410 MFWD Tractor
   / Snow Pusher Size for JD 5410 MFWD Tractor #1
landrand
Ishpeming, MI
Internation 674, John Deer 6400, Kubota BX2670, Ford New Holland 655D
I'm looking to get a snow pusher for my tractor and am wondering what size snow pusher this tractor would best handle. I have a John Deere 5410 MFWD tractor, 541 loader, no cab, with R1 Ag tires. The 5410 is a 81 HP tractor and the tires are not weighted. I don't know how much the tractor weighs. I googled the tractor weight and it could be anywhere from 5,000 to 8,700 lbs. I have a small farm and need to use the tractor to clear about 1.5 acre cow corral as well as around my outbuildings.
I live in the UP of Michigan and we get a lot of snow during the winter. The local L & M Fleet store has a Tartar 8' snow pusher that weighs about 870 lbs and am wondering if this would be fine or should I consider something bigger. Any input or recommendations would be greatly appreciated.
   / Snow Pusher Size for JD 5410 MFWD Tractor #2
I think it would match up to your tractor/loader about perfect, only thing I would suggest is add some weight to rear end for better traction. Either filled tires or 3pt counterweight or better yet both
   / Snow Pusher Size for JD 5410 MFWD Tractor #3
I would not be considering anything larger than the 8' pusher you are looking at. Maybe even considering something just over the tractor width.
I would rather make an additional few passes than run out of traction 1/2 way through a push. So much is dependant on the snow though...
   / Snow Pusher Size for JD 5410 MFWD Tractor #4
I have a 1K rear blade on the 3-point and 1550 pounds of RimGuard in the rear tires. This added weight really helps when moving snow.
We NEVER get snow like on the UP - thank goodness. I really would not want to go back to a 3-point, PTO driven snow thrower. My neck & shoulders start twitching/aching - just at the thought. I have racked more than enough time with a thrower on my first tractor.
FWIW - you are very likely to run into snow conditions that make the eight foot blade too large. Simple answer - raise the blade and take less snow with each pass OR just take a smaller bite. Nobody says you have to take full width - full depth with each pass.
2285 (A58376)
2285 (A58376)
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
NEW Woods Reverse Rotation 5ft Tiller (A55301)
NEW Woods Reverse...
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
2202 (A58376)
2202 (A58376)
2014 Takeuchi TB290 Mini Excavator, S/N 1851007797, Diesel Engine, Tag 24" Bucket w/Thumb, 18" Wide (A59076)
2014 Takeuchi...
