Snow pusher on gravel.
   / Snow pusher on gravel. #21
Thanks for the visual DJ54. If only I was a welder!:confused3:
There's only one way to learn.When I was around 14, Dad sat me down with a pile of scrap metal, and a 50 lb. box of 6011, 1/8"rods. Still have the old Mid-States 180 amp buzz box, and still works fine. I've since graduated to a good used Millermatic 200 MIG. Great for new steel, but still use the old Mid-States, and vintage tall upright Lincoln 180 amp welders, for doing repairs on some not so new steel, on whatever.
I fix, and build a lot of things around here, but when it comes to custom built truck hitches, I take it to a pro.
Yeah, that’s what I thought when I jumped in with both feet when I needed to weld something on my equipment trailer. A buddy of mine lent me his cheap Harbor Freight welder, and I decided I pretty much sucked at welding (of course maybe the welder wasn’t the greatest either) In any event, if I ever really need something important welded, I keep my welder neighbor down the road from me in business!
   / Snow pusher on gravel. #23
I plow 325' of gravel drive with this setup, and by packing down a layer of snow. I only move about a 5 gallon pail of gravel each season.
The casters allow the plow to be set above the gravel, until a base is compacted. Once a base is there, I can put the blade all the way down.
It also has a steel pipe in font of the cutting edge.
You DO NOT need to slit the steel pipe. It's a lot of unnecessary work. Just weld 2 tabs on it, and bolt it to the front of the plow.
   / Snow pusher on gravel. #24
OP, 3 questions
1) when you use a snow pusher, do you put it in float, and is the adjustable rubber piece int he back even with the metal?
2) When you use pipe, are you using schedule 40 or 80?
3) You are talking about a snow pusher right? not a snow blade or rear blade or box blade correct? I see people talking about a lot of other equipment ideas that might not work with a snow pusher.
I have a different issue than you, I need uhmw pads/skids, the vendor sells them, but they want 560.
   / Snow pusher on gravel. #25
I run a heavy truck plow with shoes on it. Sometimes the road is so soft that the shoes don't provide enough float so I get two grooves from the shoes plus the blade digging in. In those cases I take off the shoes and raise the plow a hair to take the weight off the cutting edge and plow the road that way. It makes a messy plow job because the angled blade is not parallel to the road surface every where and in the dips and rises I leave piles. But then I just back drag the whole thing to neaten it up. It does leave a little snow on the road but that is fine by me.
gg
Agree. I also back drag to leave a nice finish.
However for early season results I have welded oversized 'shoes' onto my blower so as not to blow gravel and on my angled plow blade I added one oversized to the dragging corner blade.
Works!
I made that oversized shoe like 10" with an upturned front. (like a small sled) as I found that the factory mushroom skids simply dug in much too much.
   / Snow pusher on gravel. #26
With my 8.5 v-plow on my truck, I have had good luck running the truck up and down the road or driveway to pack the snow down and give the shoes a compacted base to ride on.
   / Snow pusher on gravel. #27
Yep!
I do same when first event is a mere 3-4 inches as for sure you want a base to work on.
However nothing is worst than 8 inches of wet on unfrozen ground as we had.
Shucks gravel, grass and shrubs all took a beating this year.
The city plow truck even plowed more gravel than snow.
   / Snow pusher on gravel. #28
Yep!
yes. our first real snow was 16 inches on the warm ground! my drive is all tore up.
   / Snow pusher on gravel. #29
All the way down, then 2 taps up seems to be the key for me. But I'm gonna put a pipe on the edge too. Or move south.
2019 MACK GRANITE (A58214)
2019 MACK GRANITE...
2021 Bobcat E50 R2 Series Excavator w/ Push Blade & Hydro Thumb (A59213)
2021 Bobcat E50 R2...
GEARMATIC WINCH (A58214)
GEARMATIC WINCH...
JOHN DEERE 544G WHEEL LOADER (A58214)
JOHN DEERE 544G...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A56438)
2017 Yale GLC050VX...
2017 Nissan Titan (A55788)
2017 Nissan Titan...
