Snow pusher on gravel.
   / Snow pusher on gravel. #1
b737drvr
Does anybody have experience with a snow pusher box on gravel/crushed asphalt? I have been plowing our 1/8 mile lane for the past several years with an ATV plow and tractor backblade for the really heavy snows. Not real happy with either of those methods as they just tear up the lane too badly. Too much of my gravel/asphalt ends up on the side of the road. Have a Kioti DK40 and Bobcat T770 that I could push with. Any thoughts are appreciated.
   / Snow pusher on gravel. #2
i have 3 6 in wide sections of 4 in pvc jammed on edge of a back blade, works pretty well and does not tear up the gravel much. it really comes down to having some kind of shoe on the blade.
   / Snow pusher on gravel. #3
I use an atv and llow on pea gravel without any issue. Do you have the plow skids set at a height so it wont rip up the gravel? Atv plowing is sooooooo much faster!
   / Snow pusher on gravel. #4
I have a mile long gravel driveway. I clear snow with a very HD Rhino rear blade. If I need to clear snow before the driveway has frozen, rock hard - simply reverse the rear blade 180 degrees and plow forward. It will nicely clear the snow and leave the gravel right where it is.
   / Snow pusher on gravel. #5
I just bought one for gravel parking lots and a few drives to combine with my snowblower. Haven't had a chance to use it yet and am picking it up next week.
Probably not helpful now, but I will update any info after a few uses.
I'm sure if the ground is frozen or not plays a big role in how well it works.
   / Snow pusher on gravel. #6
I run a heavy truck plow with shoes on it. Sometimes the road is so soft that the shoes don't provide enough float so I get two grooves from the shoes plus the blade digging in. In those cases I take off the shoes and raise the plow a hair to take the weight off the cutting edge and plow the road that way. It makes a messy plow job because the angled blade is not parallel to the road surface every where and in the dips and rises I leave piles. But then I just back drag the whole thing to neaten it up. It does leave a little snow on the road but that is fine by me.
gg
   / Snow pusher on gravel. #7
I have the same situation as you with my driveway landing strewn with 3/4" gravel. I also use a snow pusher as well as a back blade. I find it nearly impossible not to pick up stones and blade height lift off the ground is of little consequence. What happens is the snow itself (on the first dump anyway) picks up the stones and rolls the stones to wherever my tractor goes. It is an unavoidable consequence that I have dealt with for the 42years I've lived here. I simply pull the stones back every season. It's akin to having logs with dirt or mud on them but you need to cut them up anyway. It would not stop me from using a chainsaw.
The snow pusher is a great tool to have to clear wide swept "areas". Nothing beats a plow in my mind for speed when having to clear "lanes".
When there becomes a hard pack snow covering, there is no problem with either tool.
   / Snow pusher on gravel. #8
I tried the PVC but it kept breaking.
Then someone on this forum suggested angle iron.
He used 3". I didn't have any so tried 2" bolted to my york rake.
Worked GREAT.
Next I used a section of old bed frame on the ATV plow I have on my tractor.
I can now plow the drive without disturbing the gravel even before it freezes and a path to the barn over the grass with no trace of any damage in the spring.
   / Snow pusher on gravel. #9
Same here. I have the adjustable feet on my front blade and it works great.
Thanks again everybody for what you use on your gravel surfaces. I have tried several iterations on the ATV plow and back blade all with varying successes (and failures). Just hoping somebody could shed light on those big snow pusher boxes. Please let me know Bridge4 when you get that new pusher!
CATBKTSSL_78 (A55787)
2017 Chevrolet Tahoe SUV (A56859)
2017 Chevrolet...
New/Unused SD Lanch 12x20 Enclosed Carport (A57454)
New/Unused SD...
CASE INTERNATIONAL 4R DANISH TINE CULTIVATOR (A52708)
CASE INTERNATIONAL...
3 HOLE FOOD WARMER (A58374)
3 HOLE FOOD WARMER...
202480 (A54757)
202480 (A54757)
