Snow Pusher on compact Tractor
   / Snow Pusher on compact Tractor #11
A front plow will serve you a lot better than a pusher on long straight runs.
   / Snow Pusher on compact Tractor #12
there are pushers with trip blades, check out HLA's web page:
HLA Snow
   / Snow Pusher on compact Tractor #13
I have used a 7' pusher on my 4630 for some time. Loaded tires no chains. It works good in parking lots but I do not like the rubber edge. It has a difficult time getting down to the asphalt.
   / Snow Pusher on compact Tractor #14
We had our first chance over the weekend to try this set up out. 8' Boss pusher with steel trip edge on 50hp New Holland. Moves snow just as well as our Boss V plows on a truck with much better visibility. No chains, but some additional rear weight would be nice.
   / Snow Pusher on compact Tractor #15
Nice:thumbsup:,, I just don't understand the difference between a pusher VS a bucket.
To me, they do about the same job:confused:
   / Snow Pusher on compact Tractor #17
A snow pusher holds more snow than most buckets. Work much better for clearing large areas.
   / Snow Pusher on compact Tractor #18
I have the same set up. But with 2 link v-bar chains on the back and if it gets real bad I put them on the front also. Loaded tires and a 1400lb blower on the back. It pushes real well! CJ
   / Snow Pusher on compact Tractor #19
Nice:thumbsup:,, I just don't understand the difference between a pusher VS a bucket. To me, they do about the same job:confused:
I found a deal on a 7' pusher. Not sure how the tractor will handle it. If it doesn't do well, I'll still keep it for when I upsize the tractor.
Say you have a 1/2 yard 3/4 yard or even large 1 yard bucket..... My little 7' pusher holds 6 yards of snow. So even it I only fill her half way, I'm still saving a boat load of time.
   / Snow Pusher on compact Tractor #20
I also use this setup for the roadway.
Worked well last year until I broke the " A" frame. It back and ready to work again after being shortened up. I threw a coat of paint on her to pretty her up. She could use some more sanding and paint but as long as it's functional.
7' 6" western. I have removed the hydraulic Rams so I manually turn it for now. Eventually I'll have remotes or a third function and I'll add Rams. Maybe on this tractor or the next. Either way, this setup seems to work.
Case 930 Tractor (A59814)
Case 930 Tractor...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
2021 WANCO, INC LIGHT PLANT (A58216)
2021 WANCO, INC...
2007 Toro ProCore 648 Walk-Behind Turf Aerator (A56857)
2007 Toro ProCore...
2012 Ford Focus Sedan (A56859)
2012 Ford Focus...
JOHN DEERE 544G WHEEL LOADER (A58216)
JOHN DEERE 544G...
