Before I got my compact, I plowed with an Allis Chalmers 16 hp garden tractor with a 47" dozer blade with skids on it, I used wheel weights and chains on a gravel driveway in south-central Michigan. Without the chains, it went about nowhere, my driveway is flat and about 140' long. It did better with chains and without weights than the other way around but was best with both. The skids allowing it to not dig into the lawn when I piled up the snow. One winter with heavier snows, we had a heavy wet snow and with the blade on full angle, I couldn't bust through the middle so I had to use a little snowthrower to cut a path through the middle, then the tractor would peel it side to side.
Last winter (not much snow here) my NH TC18 did a better job than the garden tractor did with only front weights, no chains but 4x4. I used my back blade in the reverse position and it cleared fine but I would still like to attach some skids or wheels to it in case we get real snow this winter.
The only other thing to do is gain some weight to help traction, eat a big breakfast before you go plow! /w3tcompact/icons/laugh.gif
JimBinMI
We boys and our toys!
