Snow Plowing with a RTV
   / Snow Plowing with a RTV #11
yea I have a large ara. I had er out this morning in the 8 degree F cold and the spreader worked like a charm. VERY nice unit. The heat worked fine in this cold too. The temp gauge went to 1/4 and stayed there..
Frank
   / Snow Plowing with a RTV #12
heres nother pic of the spreader..
   / Snow Plowing with a RTV #13
That is one sweet sanding unit. Do you have a remote up front that is not wired to the rtv electrics?
   / Snow Plowing with a RTV #14
yes I do. One cab switch to start the 3.75 hp B&S engine and another to start the conveyer to move the salt out to the back of the hopper and onto the slinger that is turned by the B&S emgine.. It works just like a big pickup mounted salt spreader.. only smaller..
Frank
   / Snow Plowing with a RTV #17
First plow my gravel camp roads with a Honda Foreman, to freeze them down. Use a larger piece of equipment when the snow gets too deep for the Honda. If I start with the larger equipment, end up pushing too much of the gravel off.
Attaching 3 pictures of the Foreman at work.
penokee /forums/images/graemlins/smile.gif
   / Snow Plowing with a RTV #18
Honda with back-up Operator.
   / Snow Plowing with a RTV #19
Handles a full blade with no problem.
   / Snow Plowing with a RTV #20
I have been giving the RTV some serious consideration. How does the snow plow raise and lower, is it connected to the hyd. for the dump bed or by hand?
Mike
2006 Wells Cargo 8x16 Trailer (A55973)
2006 Wells Cargo...
UNUSED FUTURE FT13 EXCAVATOR (A57192)
UNUSED FUTURE FT13...
USED (2) 7000 LB AXLES W/ BRAKES & 4" DROP (A57192)
USED (2) 7000 LB...
2018 New Holland C227 Compact Track Loader (A55315)
2018 New Holland...
20205 Lucky Dak Electric Scooter (A55853)
20205 Lucky Dak...
2018 Ford F350 (A55973)
2018 Ford F350...
