Snow Equipment Buying/Pricing snow plow or fel B7100
   / snow plow or fel B7100 #1
autodoc1
Ill.
kubota B7100 hstd / B7100hste
I have a 25 car parking lot. That I need to remove snow. I have a 5 foot rear grader blade but it doesn't trip. When it caches the pavement. Also a pain in the neck. Would like a front mount blade or loader with a blade.
   / snow plow or fel B7100 #2
Hi,
If you look in your local ' Buy & Sell ' you should be able to find an old plow ( i know there a lots kickin around up here .......... ) and modify the mounting ears to hook onto your loader. lengthen the lines to run to a remote ( if you have one ) and you are done!!
Take care
Will
   / snow plow or fel B7100 #4
I agree with Egon - an angled blade will kick the front end around with ease when pushing those banks on the second or third pass. The further out in front the blade is mounted, the worse off you will be. Have you tried adjusting the top link on the 3PH to make your rear blade take a less agressive bite? That might help it bounce over the snags.
Brad
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A52748)
2006 Magnolia Dry...
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
2008 Genie S-65 65ft Telescoping Boom Lift (A50322)
2008 Genie S-65...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
P.T 8' Offset Disc Harrow (A50120)
P.T 8' Offset Disc...
