Snow plow mount on Kioti LB1914
   / Snow plow mount on Kioti LB1914 #1
gladehound
PA
Kioti DS4510HS, Exmark Laser Z, Kioti LB1914
Hi all. Just finished installing a snow plow mount on my tractor and I can't wait to try it. Pictures are below. I can't take credit for the metal work, that was done by a friend. I mocked up the wood template. Sent it to him to fabricate. I made minor adjustment to the holes to bolt it to the tractor, painted it and attached it with eight Grade 8 1/2" bolts. I'm hoping this will help with steering with an angled blade compare to hanging the plow off the front of the bucket. :D
   / Snow plow mount on Kioti LB1914 #2
Very nice. Thats quite the brush guard you have there, reminds me of a n.j. forest fire truck. Are you going to leave the FEL on while the plow is on and use it to lift the plow?
Thanks... the same guy did the metal work for the cage. Yes, I'm going to leave the Fell on. I just leave it all the way up, put a chain on the back of the bucket and dump it half way to lift the plow. Curl it to put the plow back down. I like having the extra weight of the fell on the front wheels to help with steering.:thumbsup:
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2021 DEERE 333G LOT NUMBER 198 (A53084)
2021 DEERE 333G...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
480/70R38 LOT NUMBER 135 (A53084)
480/70R38 LOT...
Industrial Air Contractor Air Compressor (A51573)
Industrial Air...
