Snow Plow Hydraulics Problem
/ Snow Plow Hydraulics Problem #11
Jack, parts for that unit will crossover to the older fisher plow parts (pump, valve, rams ect)
Do yourself a favor and go to the nearest Fisher dealer and buy the new style low-pressure return filter and change the hyd oil very clean in the reservoir, mount the filter inline on the return hose in-line
those plows are notorious for the gear pumps failing and spitting metal fragments into the reservoir and cylinders and eventually ruining the hyd valve (which will lead to damaged valve spools)......the new low-pressure filter is an insurance policy for ya in case the pump fails or prevent failure
http://library.fisherplows.com/ddcommon/dd_pdf/pdfs/26404_061504.pdf
Fisher part# 8764
Thanks for the advice I'll check into that tomorrow.
2008 Freightliner Allegro Bay Class A Motorhome (A59231)
2008 Freightliner...
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
CFG Industrial H15R (A60463)
CFG Industrial...
2007 Ford F-750 2,000 Gallon Water Truck (A60352)
2007 Ford F-750...
John Deere 6110M (A60462)
John Deere 6110M...
