Snow Plow Hydrauilics.
   / Snow Plow Hydrauilics. #1
horsinaround
down the road a bit
Kubota L5740 Kubota F3080
I bought a Curtis snow plow and am mounting a QA plate to it for my tractor.
The angle cylinders are frozen up. Any insight on repair or replace?
I figure I can take them to a local hydraulic shop and have them rebuilt, or I can buy new ones, or I can just hook the hoses to them and see if they bust loose. I don't really like the last option as I don't want to run the nastiness in the cylinders into the hydraulic system.
Has anyone had snow plow cylinders rebuilt? Is it worth it? I have looked for curtis parts on line and the sources seem very limited.
I won't use this plow much, as it is just for my farm, but when I use it, I want it to work. I am looking for the cheepest way to get it reliable.
   / Snow Plow Hydrauilics. #2
I have rebuilt the SA (single acting) cylinders Meyers uses on their plows, I am sure the Curtis ones are the same or similar...
They are very east to get apart, just remove the "gland nut" on the cylinder and then the rod/piston will pull out. You said they are "frozen up" so you may need a little tension to pull them out-or air pressure applied to the ports works sometimes also.
If the rods are rusted/pitted badly, don't waste your time-new cylinders can be found for $50-$75 each.
I hadn't thought of air to push them free. I will give that a try. Can I use a big pair of channel locks to remove the gland nut? or should I go buy a wrench?
   / Snow Plow Hydrauilics. #4
I use a pipe wrench when I did mine...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A52377)
2021 Freightliner...
2019 Dodge Durango AWD SUV (A53424)
2019 Dodge Durango...
2019 CATERPILLAR 289D3 SKID STEER (A52705)
2019 CATERPILLAR...
2011 New Holland B95B Cab MFWD Loader Backhoe (A55218)
2011 New Holland...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
KUBOTA M5660 SU TRACTOR (A52706)
KUBOTA M5660 SU...
