Snow Plow Hydrauilics.
   / Snow Plow Hydrauilics. #1
horsinaround
down the road a bit
Kubota L5740 Kubota F3080
I bought a Curtis snow plow and am mounting a QA plate to it for my tractor.
The angle cylinders are frozen up. Any insight on repair or replace?
I figure I can take them to a local hydraulic shop and have them rebuilt, or I can buy new ones, or I can just hook the hoses to them and see if they bust loose. I don't really like the last option as I don't want to run the nastiness in the cylinders into the hydraulic system.
Has anyone had snow plow cylinders rebuilt? Is it worth it? I have looked for curtis parts on line and the sources seem very limited.
I won't use this plow much, as it is just for my farm, but when I use it, I want it to work. I am looking for the cheepest way to get it reliable.
   / Snow Plow Hydrauilics. #2
I have rebuilt the SA (single acting) cylinders Meyers uses on their plows, I am sure the Curtis ones are the same or similar...
They are very east to get apart, just remove the "gland nut" on the cylinder and then the rod/piston will pull out. You said they are "frozen up" so you may need a little tension to pull them out-or air pressure applied to the ports works sometimes also.
If the rods are rusted/pitted badly, don't waste your time-new cylinders can be found for $50-$75 each.
I hadn't thought of air to push them free. I will give that a try. Can I use a big pair of channel locks to remove the gland nut? or should I go buy a wrench?
   / Snow Plow Hydrauilics. #4
I use a pipe wrench when I did mine...
2017 Ford F550 Altec Bucket Truck (A52377)
2017 Ford F550...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55301)
2017 KINZE...
2015 TROXEL 130BBL KILL TRAILER (A53843)
2015 TROXEL 130BBL...
2023 Maxx-D TDX Tandem Dual Flatbed Tilt Trailer (A55218)
2023 Maxx-D TDX...
