Snow snow plow for DK 35 ?
   / snow plow for DK 35 ? #1
n1wjr
GRANTHAM,N.H.
KIOTI DK 35
Hi,all I have a DK 35 with a KL 1450 FL. and dont have the quick attach bucket.
I want to hook up a older style snow plow, so this summer I want to get one and figure out how to make it work,has any one else on here done this already?
Also what size will it push 7ft 7.5 or 8 ft ??
I have seen this done with other tractors but they all have a different ways of doing it,I just want some Ideas and put them all together and come up with the best one for my tractor.also the best way to hook up the hydrolic lines I have the two remotes in the back.
thank you
matt
   / snow plow for DK 35 ? #2
I use a 7 ft.on mine but I turn it by hand. With my drive I can angle it to the right and make one pass each way without changing the blade angle. I attached mine by cutting 2, 2" holes in the back of the bucket, slipping the two attachment points through the holes and pinning them. I hook a chain from the blade to the chain hook welded on the middle of the bucket and it works great.
When I take it off in the spring I use 4 pieces if steel with a 5/8 bolt in the middle and just put one piece of steel on each side of the cutout and bolt them together.
   / snow plow for DK 35 ? #3
I run a 7' front snow blade. (no power angle).
I have the skid steer type quick attach.
ok sounds like a 7 ft. plow will be big enough ,I am hoping to get an older fisher plow with power angel and connect the hoses to my remotes in the back!!
Toadhill I like the idea of cutting a hole and putting pins in.
Can you angle your plow all the way,or does it hit the bucket?
thanks guys
matt
   / snow plow for DK 35 ? #5
I can angle it all the way, and still have about 6" clearance.
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
2024 Timpte 40ft Hopper (A55315)
2024 Timpte 40ft...
Kubota L3130 (A53317)
1999 Volvo Dump Truck (A55973)
1999 Volvo Dump...
2006 Utility Trailer MFD. T/A 32FT Dry Van Trailer (A56858)
2006 Utility...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
