Snow Snow clearing newbie - Recommended steps
   / Snow clearing newbie - Recommended steps #1
Starrynights
ontario
Kioti ck2620
This will be my first winter snow clearing with the big boy, I've moved up from a JD570 lawn tractor/blower to a Kioti CK2620 & Inverted (pull type) snowblower. That little JD tractor did surprisingly well, but just not enough for the big snow dumps we get. Anyways, since this is a new task with new equipment for me, I want to make sure I am approaching it correctly.
So this is what I believe to be the correct way to do it;
  • Warm up tractor
  • Raise 3pt hitch
  • Move into initial starting area
  • Set RPMs approx 1200
  • Clutch, then slowly release while PTO is initially engaged
  • Bring RPMs up to ~2,000
  • Get into the snow and lower the 3pt hitch to desired height above ground and start blowing the snow
When I reach the end of a pass down the driveway, is it a good idea to disengage the PTO while raising the 3pt hitch and maneuvering or does it matter?
cheers!
   / Snow clearing newbie - Recommended steps #2
Your process seems okay, except that the blower probably wants full PTO RPM, after it's engaged.
A couple questions: Gravel or paved drive? Hydro or gear trans?
Gravel takes more of your attention re: level/height.
Hydro is easier to control the speed vs snow depth challenge.
   / Snow clearing newbie - Recommended steps #3
Grease the blower fittings 1st time out and consider silicone spray on the chute. Get good safety eyewear because you WILL get flyback. Hang a stick on the tractor fender to unclog the blower fan in mushy snow conditions.
   / Snow clearing newbie - Recommended steps #4
  • Warm up tractor
  • Raise 3pt hitch
cheers!
Will this be your first time using PTO powered equipment? Generally, you want to keep the RPM's as low as possible when engaging the PTO. No reason to bump it up while engaging. Start it at idle, unless doing that stalls out the engine. Shouldn't do that since there isn't a lot of rotating mass. Once it's engaged, run it at whatever RPM the manufacturer recommends, which is probably 540 or thereabouts. You should have something on your machine that tells you when the PTO is at 540. You can raise or lower the RPM's to throw the snow more or less distance. No need to disengage PTO to raise and turn, assuming the driveshaft angle is such that raising the blower doesn't make your U joint angles too steep.
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
2015 Ford F-350 Utility Flatbed Truck (A51692)
2015 Ford F-350...
2013 Audi A4 Sedan (A55853)
2013 Audi A4 Sedan...
2008 CAT 305C (A53317)
2021 CATERPILLAR 349 EXCAVATOR (A52707)
2021 CATERPILLAR...
