Snow cleanup and tractor chippers
   / Snow cleanup and tractor chippers #1
Rebeldad1
Hughett Bend Washington
Kioti Tractor, John Deere Mower,New Holland Mini Excavator
We have a lot of small downed vine maple and assorted tree limbs. I have a Woodmaxx pto 3point chipper. Always used it on dry materials during summer.
How well do these chippers work on wet wood? Is it even worth trying?
   / Snow cleanup and tractor chippers #2
Don't worry about it.....get chippin.
   / Snow cleanup and tractor chippers #3
I have chipped wet stuff. As far as I can tell it chips the same as dry. No rust on the knives.
   / Snow cleanup and tractor chippers #4
We both live in the Pacific North Wet. Only time its not wet is when it's fire season.
   / Snow cleanup and tractor chippers #5
Wet wood chips better, as the moisture lubricates the knives and helps them stay cooler. This is the same reason green wood chips better than dry wood. The manual for my Wallenstein says to avoid chipping dry wood if possible. I have actually seen dry wood cause smoking in the chipper!
   / Snow cleanup and tractor chippers #6
If really too wet, can gum up in the chipper though. I often kept a small pile of dry stuff to throw in every so often if chipping/shredding wet or greenish material.
When I collected leaves in the fall of our very wet 2018, they were far too wet to run through the shredder. I just had to pile them up on my compost pile and let them degrade. Took a lot longer.
Think limbs and stuff would have to be pretty wet to not chip well unless they're wet and green.
Ralph
   / Snow cleanup and tractor chippers #7
I'm also in your neighborhood, in Snohomish, Washington, and I have a Woodmaxx standalone chipper. The instructions for the machine actually tell you that green and wet wood is better for the chipper, because the moisture acts as a lubricant. The chipper loves eating entire vine maples, by the way. Do take care in feeding lots of moss-covered stuff in, however, as it can jam the machine.
   / Snow cleanup and tractor chippers #8
Wet or green trees chip like greased Twinkies. Dry trees are a whole different matter. Chip while wet or green.
(1) Multi-Trunked Non Fruiting Olive Tree w/ Military Barrel (A59225)
(1) Multi-Trunked...
LOT: Assorted Vise Grips (A59076)
LOT: Assorted Vise...
TPM 10 Piece Mini Excavator Heavy Duty Attachment Set (New/Unused) (A59225)
TPM 10 Piece Mini...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
TIRE & RIM, SKID STEER PLATE, MISC HITCHES & PARTS (A52708)
TIRE & RIM, SKID...
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
