Snow snow chain modification
   / snow chain modification #11
Great info! I appreciate the experience...I do have one follow up question.
I do have two bungie cords on the outside of each wheel (criss crossed), but can you use them on the inside? I do think if I did it would help keep the chains centered. and I see where the additional bungies or ties for the loose ends would help keep the loose ends from flapping.
You normally don't need them on the inside. If you think about the circle of the chain edges formed by the joining of the inner edge chain ends together and with tension on the outside pulling against it. how can the inner circle move, as it is under tension and cannot slip over the edge of the tire. If the outside tension is even the inside should not migrate. I don't think I explained this very well, but hey I gave it a shot.:)
   / snow chain modification #12
I do use Bungee cords to take up slack of chain on the sides 2-3 per side.It makes a big difference.
   / snow chain modification #13
i had trouble with bungee cords getting too cold and brittle.then losing their retraction strength. I like the spring tensioners i have now. they suck to install, but never loosen up.
   / snow chain modification #15
Imagine a clock....1st cord/bungie 9-2, second one 10-3, third one 11-4 and so on. If you have 5 bungies on the inside, then put 5 on the outside. I had a set of way too big chains on my Farmall that came off a skidder and they worked real good for me using that pattern.
I still have those chains and I will be putting them on my Kioti for next winter. Along with the chains I have for my Jeep which are for 15" tires. The Kioti fronts are 14's.
   / snow chain modification #17
If you have tires with lugs of any kind as opposed to turf tires, you don't want your chains "good and tight" You'll get better traction with chains a bit loose. Zip ties are good to tie off extra links. I have no side tensioners on my chains at all.
+1 on this. Had mine too tight and found they had an opposite effect on traction.
Pulled off the Bungee "tensioners" and loosened a link and my world was rocked. 10x better.
I too use cable zips to tie up the extra chain.
-J
   / snow chain modification #18
-J
Okay, I will sit corrected. AND I will keep that in mind for next winter.
I learned on truck tires.
7022 (A50322)
7022 (A50322)
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
2014 Brent 1596T Dual Auger Grain Cart (A50657)
2014 Brent 1596T...
2017 MACK CHU613 TANDEM AXLE SLEEPER (A51222)
2017 MACK CHU613...
Kinze 3500 8 Row Vac Planter (A52349)
Kinze 3500 8 Row...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
