Snow Snow Blower Vs FEL Mounted Snow Plow
   / Snow Blower Vs FEL Mounted Snow Plow #1
bdhsfz6
Elite Member
Northeastern Pennsylvania
Kubota MX5800 HST & L6060 HSTC Formerly L6060 HST B7100 HST, L2550, L3010 HST, L3430 HST
I've been moving snow for many years here in northeast PA. I clear 1.25 miles of private gravel road and several driveways. I've had rear mount snowblowers and FEL plows on all of my Kubotas but do most of the work with the FEL plow. I can move 5 times as much snow in half the time than I can with the blower. There are some seasons where the blower isn't used at all and I just keep it mounted for ballast. The blower is used mostly in deep snow when the banks get too high or in tight quarters where places to pile snow are limited.
Since FEL plows are a bit cheaper, have fewer moving parts and do a better job on unpaved surfaces, I'm curious why blowers seem to be so popular here. I'd appreciate comments as to your preference and why.
   / Snow Blower Vs FEL Mounted Snow Plow #2
I have both an FEL PA plow and a rear blower and agree the plow is much faster. I keep the blower on for extra rear weight mainly. I plow my own driveway but use the blower on a few neighbors driveways. In my driveway the blower is used to knock down piles later in the season. Blowers are probably popular because you don't have piles to contend with later.
   / Snow Blower Vs FEL Mounted Snow Plow #3
In Central NY where you may get 200" per year and dumps of 20-30" at a time a blower is the proper tool.I lived and worked there for ten years and saw a number of storms of 40-50" over a couple days.
Where I live now in Northern NY we don't get snows like that usually so a FEL mounted plow is my tool of choice.
   / Snow Blower Vs FEL Mounted Snow Plow #4
Most storms we get here in Northern Maine are 20-30 inch storms, a blower is the tool here otherwise you have to push way back in the beginning of the season which makes for a lot more work.
   / Snow Blower Vs FEL Mounted Snow Plow #5
Plows are faster. Once you get over 3 feet of snow on the ground and snow plow banks are over 6 feet tall you are SOL with a plow.
Snow Plow
Pros
1. fast
2. cheaper capital cost - don't need a PTO or second engine to drive impellers on snow blowers
Cons
1. snow banks
2. limited snow disposal area - you are looking at moving all the snow and dumping it in a swarf zone about 6 feet from your plow
3. the more snow you need to move the heavier it is and you need bigger machines to do it
4. deep snow banks makes it more susceptible to flooding/damming and turns your driveway/parking lot into an ice rink during thaw/freeze
5. can't get into tight areas - you end up with a long machine and you need speed to push snow farther away
6. deep snow banks impact visibility - if you get 6 foot deep snow drifts piled at the end/sides of your driveway you can't see anything pulling out onto the road
7. deep snow banks cause more snow drift problems - rule of thumb every 4 inches of snow can create 12 inches of drifts. If you have a 3 foot snow bank on the sides of your driveway you end up with 3 foot deep snow drifts blocking your driveway and your driveway is impassible to cars and tough to push away
8. snow plowing compacts the snow, compacted snow turns into ice
9. wet snow getting plowed followed by freeze up = guaranteed ice rink for a driveway
Snow Blower
Pros
1. Throws snow 50+ feet away - almost no snow banks because it has a very large swarf zone
2. cuts deep snow easily and requires less machine weight and HP to move it
3. cuts deep impacted snow like snow banks and snow drifts no problem
4. allows melt water to flow away easier because you don't form ice dams from compacted snow
5. less snow drifting issues - your cars don't get stuck as quickly
6. you can clear tight areas easily
7. compacted snow turns your gravel driveway into an ice rink in spring
8. wet snow followed by freeze up? blower throws wet snow away, you get less compaction and less likely to get ice rink
Cons
1. higher capital cost - need PTO or second engine to drive impellers
2. takes longer time than plowing - at least initially at the start of the season
3. if you have a gravel driveway you have to leave a skim layer of snow or you throw stone/rocks all over your lawn
4. newspapers. rural newspapers get delivered onto your driveway the night before a heavy snowfall in plastic baggies that look like newspaper sausages. These are guaranteed to jamb your secondary impeller and break shear bolts
5. finding rocks/branches/recycling with your snow blower
Bottom line - if you live in a snow belt area you will eventually buy a snow blower because it makes the most sense and save you time and frustration in the long run. If you live in a banana belt area and only get occasional snow then a snow plow will probably work out fine for you.
I have a neighbour with a 1 ton truck and a plow that he uses for his snow clearing business. By mid to end of season he has to ask me to clear away his snow banks because he runs out of room to push the snow. He also complains about flooding in spring even though his house is on a hill. My gravel driveway turns into an ice rink for a couple weeks every spring but I never have flooding issues.
   / Snow Blower Vs FEL Mounted Snow Plow #6
Snow Plow
Pros
1. fast
Cons
1. snow banks
Snow Blower
Pros
Cons
I have a neighbour with a 1 ton truck and a plow that he uses for his snow clearing business. By mid to end of season he has to ask me to clear away his now banks because he runs out of room to push the snow. He also complains about flooding in spring even though his house is on a hill. My gravel driveway turns into an ice rink for a couple weeks every spring but I never have flooding issues.
Well said..
   / Snow Blower Vs FEL Mounted Snow Plow #7
I have used both. The main driveway coming up to the house is about 1/4 mile long through the woods. With my plow or snowblower it is out and back followed by out and back and the driveway is clear. When I was plowing, I would need to move the banks back or run out of room for the next storm. This has gotten so bad in some years that I had to have my dad come over with his blower and remove the banks.
The area near the house I have more room to pile snow, so plowing wasn't so bad until spring where I damaged the lawn. And the kids loved the snow piles.
My entire driveway is paved. The snowblower may be slower initially but I never need to take the time to move frozen snow banks back. Also as stated earlier, this does help with the drainage on the freeze and thaw cycles.
   / Snow Blower Vs FEL Mounted Snow Plow #8
The conundrum I have is that I live in Virginia. Generally, we have a mild climate, but every few years we get a 30" snowfall.
Question is, is it worth it to buy a snowblower?
   / Snow Blower Vs FEL Mounted Snow Plow #9
One of my main reasons for trading in the Ford 1700 4WD and getting the Kubota M6040 4WD was tractor weight. The Kubota with front grapple, beet juice in the rears and heavy duty Rhino rear blade weight 10,100#. I have a mile long gravel driveway and about half way thru the winter I'd have to use the 3-point blower with the little Ford. It just was not heavy enough to move the frozen berms with the rear blade. The Kubota with the Rhino rear blade doesn't even break a sweat moving the frozen berms.
It took 3+ hours of solid blowing to clear the driveway, parking lot and mail box area with the blower. I get the same areas done with the rear blade in 1.5 hours. Plus the rear blade allows me to operate in a "normal" forward position. My neck & shoulders would get so stiff & sore after clearing with the blower - no amount of Jack Daniels would alleviate the pain. AND - no matter which way the chute is pointed, fine powder snow would always drift back on me, sitting out there in the open.
Obviously, the preference of a FEL plow or snowblower depends on where you live, the size of the area to be cleared and your annual snowfall.
For relatively short paved driveways in urban or suburban neighborhoods, the blower would likely be the best choice.
For longer unpaved driveways, private roads and parking areas, the plow would usually be the right tool for the job.
Several posters mention the limiting factor for a plow is the height of the snowbanks. When the banks get to be a problem on my private road, I push them back and pile them higher at a 45 degree angle to the road. With the 8' FEL plow on my MX5800, using chains, I can easily pile the banks to a height of 8' or more. I realize this method can be limited by trees, shrubbery or other obstacles along the road. Despite the multiple passes required, the operation is still faster than the blower. Beyond that, I'll resort to the 3 pt woods 74" snowblower. Luckily for me where I live, this only happens once every 5 or 6 years.
2007 Chrysler Pacifica SUV (A51694)
2007 Chrysler...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
2018 Nissan Sentra Sedan (A51694)
2018 Nissan Sentra...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2020 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2020 KOMATSU...
