Snow Attachments Snow Blower Packing Up With Snow
   / Snow Blower Packing Up With Snow #1
Larkspur, Colorado
John Deere 4520 CUT
Colorado got hit with a pretty powerful spring snow storm last night - 20" of wet heavy snow for me. Anyways, I spent a few hours moving snow from point A to point B this morning, but my snow blower chute kept packing up. I have a JD 4520 with 72" Farm King blower. I was running the PTO at the proper speed. I would normally liberally apply some Fluid Film to the chute, impeller, etc before working, but I couldn't this time. This normally seems to help, but I was wondering if anyone else has some good ideas to keep the chute from packing up.
   / Snow Blower Packing Up With Snow #2
" I was wondering if anyone else has some good ideas to keep the chute from packing up. "
metamucil ?
sorry just couldnt help myself, i have the sense of humor of a 3rd grader.
but to answer your question i use spray vegetable oil in a can (pam, but from a buddy that owns a restaraunt) and i use it every time. no buildup at all. your fluid film prolly does the exact same thing.:)
   / Snow Blower Packing Up With Snow #3
I find the faster you go in wet snow the less it clogs. But I haven't done that in twenty inches of snow.
   / Snow Blower Packing Up With Snow #4
Never had good luck with the "faster thru the wet snow" method here.
I have had better luck taking only 1/2 pass at a time. IE... blower is 60" wide.... take a 30-40" bite at it. Takes more time but has worked for me. Also I use Prestone silicone spray on my chute, impeller, and auger, and has helped "slick" things up.
   / Snow Blower Packing Up With Snow #5
I've also used silicone spray with good results.:thumbsup:
   / Snow Blower Packing Up With Snow #6
My first thought was your RPM but you said you were up to speed. Always found that made a difference with the heavy wet stuff - especially when we are getting into the spring. Just curious - 3 or 4 blade fan? Based on the Farm King web site - looks like 4 blade is an option? Discussions here on TBN, have suggested 4 blade snow blowers have an easier time with the heavier snow.
I have a three blade fan. A four blade fan is a good idea - I'll check into that. From the sounds of it, not using a spray lube may have been my problem today.
   / Snow Blower Packing Up With Snow #8
I find slower and or less bite tends to work best in heavy wet stuff -- JMHO
   / Snow Blower Packing Up With Snow #9
I have the Farm King 74" blower. It has the 4 blade fan and I have not had a problem. I just looked at the specs online and it says that the 24" 3 blade Fan is standard. I didn't order anything special and not sure why I got the 4 blade fan.
   / Snow Blower Packing Up With Snow #10
Dear Sir
I hate wet snow also. I have found you need to keep a steady flow through the machine but not let it over load. 1/4 cut or 1/2 cut depending on the depth of snow. I have found that if I lift the blower at the need of the pass and the blower empties it self out I get alot less pack ups. I also keep a shovel handle as a poker stick to unpack the chute.
Craig Clayton
2007 LBT Hot Oil / Asphalt Tanker Trailer (A47384)
2007 LBT Hot Oil /...
2025 Swict 72in Bucket Skid Steer Attachment (A50322)
2025 Swict 72in...
2006 CIMC SZJ9341TJZ03 20FT CHASSIS TRAILER (A52141)
2006 CIMC...
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
CATALOG IS A GUIDE ONLY!! (A50774)
CATALOG IS A GUIDE...
Redneck Buck Palace 360 Hunting Blind (A50515)
Redneck Buck...
