snow blower on my john deere 425 lawn tractor stops when I back up
   / snow blower on my john deere 425 lawn tractor stops when I back up #1
philbonnie
the front pto that drives the snow blower stops everytime I back up. is the a way to bypass that feature on a 425 lawn tractor
   / snow blower on my john deere 425 lawn tractor stops when I back up #2
Does your keyswitch have an override position? I don't have a 425 but my lawn tractor has a switch position that keeps the PTO on when backing up
And Welcome to TBN
I dont think so, but now that you ask, Im not sure. Ill check that in the morning thanks
   / snow blower on my john deere 425 lawn tractor stops when I back up #4
My keyswitch has 4 positions. Off-ON2-ON1-Start. After starting the key goes to ON1 automatically. In that position the PTO shuts off in reverse. If I put it in ON2 the PTO stays running in reverse. I only mow with mine and I want my mower running fwd and reverse.
thanks I am going to check that in the morning.
ok, I just went out with a flashlight and checked. there are only stop run and start on the ignition switch.
Check pages 38-39 to operate PTO in reverse
I see that on the prints. do I have to follow that proceedure everytime I back up? or does that keep the snowblower engaged until I shut it off with the switch?
   / snow blower on my john deere 425 lawn tractor stops when I back up #9
Again, I don't have a 425 so don't know if the PTO switch stays in that position once activated or if you have to lift it each time you reverse. I believe that since its a safety feature that once you go forward the switch goes back down. PITA but that's how Mfgs. build stuff. They incorporated the feature because someone probably ran over their kid with a mower deck running in reverse.
I really don't see a need for a snowblower attachment to run in reverse. A mower deck yes but blower no.
you are probably right. I am going to try it in the morning. My cub cadet has a position on the ignition switch that bypasses this safety. thanks again for the heads up.
JOHN DEERE 2032R LOT NUMBER 239 (A53084)
JOHN DEERE 2032R...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
378467 (A51572)
378467 (A51572)
2021 JOHN DEERE 8R340 LOT NUMBER 209 (A53084)
2021 JOHN DEERE...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2013 JOHN DEERE 470G LC EXCAVATOR (A51246)
2013 JOHN DEERE...
