Snow Blade Markers Installed
   / Snow Blade Markers Installed #1
JDinVT
Vermont
Added some blade markers last night. Went to Deere, but they pushed me to aftermarket options. This is an Amazon set-up with some L brackets from Runnings. Had all the hardware kicking around the garage.
   / Snow Blade Markers Installed #2
That should work! What machine are you pushing that blade with? Does it have any way to float?
I do! I will be pushing with the 4052R. Should be just the ticket!
   / Snow Blade Markers Installed #4
Oh it'll push snow all right. I was more curious about if the blade could float with respect to it's own SSQA plate, or if you just had to float the entire loader weight. I'm wondering because I see your nice gravel there; wondering how hard it'll be not to scrape it to heck during the thaws
I gotcha! I was planning on using the loader float and using the forward/aft to have it sit flat. I am unaware of any other floats on the system - but it's a new item that's yet to be played with.
It does have two feet/skids under the plow that can be adjusted with washers. It's currently set-up for what I assume would be asphalt, so I need to fix that.
Historically I have used a bucket with the float (on my old 2320 I had prior). That stay-pack gravel freezes solid, but I am curious to see what happens in the fall/spring as you point out. Even with the bucket I needed to do a little raking each spring - oddly enough I never dug into the grass.
1974 Trimron 40' Flatbed (A53316)
1974 Trimron 40'...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
JOHN DEERE 410L LOADER BACKHOE (A52706)
JOHN DEERE 410L...
Deere 333G (A53314)
Deere 333G (A53314)
JOHN DEERE 608C (A53084)
JOHN DEERE 608C...
2016 JOHN DEERE 700K LGP CRAWLER DOZER (A52705)
2016 JOHN DEERE...
