Snow Equipment Owning/Operating S'no traction at all
   / S'no traction at all #1
dgeesaman
Harrisburg, PA
New Holland TC45DA
This is my first winter using anything other than a shovel to clear snow. I have a NH TC45DA with front end loader. Worked like a champ for our first two snows of the season. Today, not so much. I got stuck twice on what was essentially level asphalt.
It was markedly colder than before (10F) and when pushing snow on the asphalt part of the driveway, I had hardly any traction at all. The rubber tires were actually leaving ice prints that matched the tread - anywhere I was going, the weighted tires were compressing snow and making ice. Where the wheels would spin I'd make a sheet of ice. The snow conditions were 8" of powder on a clean cold driveway - it cleaned up completely with a broom. On the gravel part I had no issues, just the asphalt sections. My car with snow tires got around just fine.
What are my options when the rubber tires have no grip on the asphalt? I certainly don't think chains will be safe for the asphalt. It's not like it's a spot or two where I can spread cinders or salt - the whole 700' was super slick.
   / S'no traction at all #3
screw in studs should work.
   / S'no traction at all #4
What type of tires?
Colder weather or warm temps different traction bite w/out chains when pushing.
Have you consider rear scraper blade?
Different types of less aggressive tire chain on market,if you don't want to mark tar take lees of blade worth not to spin tires or sharp turns.
   / S'no traction at all #5
dgeesaman,
The 1st year I had my tractor I was shocked how little traction I had with turf tires and how easy it was to get stuck in just a little bit of snow. Tractor was a JD 750 with front end loader and 7' backhoe for weight/ballast. Having standard tire chains on the rear made all the difference and I feared no slope or off road situation. The bottom line is I would have never believed how much difference they make until experiencing first hand.
On my current tractor I've gone to rubber tire chains after seeing how well they worked on my neighbors tractor. The ride is not as harsh and they don't leave marks in the driveway which was a concern for some of my neighbors. FYI... The rubber chains are made fairly close to you in PA.
Rubber Tire (Snow) Chains - Traction without damage.
Many forum members buy chains from this company, which is also located in PA. They have a lot of "chain" info on their site. Tire Chains by TireChains.comj
Before you buy any chains, check your tire to inner fender clearance.
I'm running the standard R4's. Given that the treads are like 2" wide it's understandable how snow trapped underneath can't move and will simply compress into ice. Especially considering I'm on loaded tires and the total weight is around 5k.
I'm not going to use studs and chains that will damage the asphalt.
Rubber tire chains - interesting. They're like 30 miles from me too. I'm also 5 miles from Messicks. That should make someone jealous, I could use the boost today.
   / S'no traction at all #8
Operated my Kubota B2320 with turf tires for 3 winters and got stuck quite a few times, shoveled out a few times and needed a wrecker once. This year I have 4-link tire chains--- phenomenal difference--- no problems up or down hills frontwards or backwards, grass or paved surfaces. Very happy with them.
   / S'no traction at all #9
I run R4's loaded w/rear scraper blade for extra weight,also at times face same issues as you..R4's adds more tire surface less traction..grip..compare to Ag's etc.,since your plowing level and most of my plow down hill can be like night and day.
   / S'no traction at all #10
It's been my experience that a FEL isn't a very efficient snow removal attachment. Additionally, it is contributing to your lack of traction. You may want to consider a rear blade and/or a snow blower. Chains would be safe for asphalt if you get the proper type.
John Deere 5055E (A53317)
John Deere 5055E...
2006 FORD F-350 (A53422)
2006 FORD F-350...
2017 GMC SIERRA 1500 (A53843)
2017 GMC SIERRA...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
John Deere 3038E (A53317)
John Deere 3038E...
(4) GOODYEAR WRANGLER 275/55R20 TIRES (A54757)
(4) GOODYEAR...
