Snapper rear engine rider. Dead..
/ Snapper rear engine rider. Dead..
Take the carb off and set it aside. Then give it a shot of starting fluid and pull the cord. It should at least pop. That will eliminate a lot of stuff and you can then focus on the carb.
Hopefully get to it Sunday. Thanks!
/ Snapper rear engine rider. Dead.. #23
Not a small engine mechanic, but I know that (carb) float valves can stick and gas keeps running til the tank is empty. Maybe the same happens if stored at some weird angle. Don't fry your starter. I have little doubt, with patience that this can turn out well, at little or no cost.
After I got it running, I would change the oil again for good measure.
Yep, float is stuck in bowl of carb. You can research and buy a whole new chinese carb on ebay for fairly cheap. Else, you need a carb rebuild kit. Also put an inline shutoff valve on the fuel line.
Good luck. Snapper RER rear engined riders are great, simple mowers.
Thx Kyle. Leaning towards that eBay carb. Just seems like an easier fix. Hoping I can get some good use out of it. It’s like a brand new mower. 07 and it doesn’t look like anyone has ever sat on the seat.
Well, I finally got the time to pull the carb and a shot of starting fluid. Turned key, pulled cord, nothing. Pumped all the gas from the cylinder first, and drained the gas oil mixture from the crankcase.
Waited a while and tried again.
Any suggestions on what I need to do next. Beginning to think I bought a disaster. They must have seen me coming. Why else would they sell a brand new $2,000 mower for practically nothing?
/ Snapper rear engine rider. Dead.. #26
You would be surprised what people sometimes even give away.
My own trick for starting small gassers, two and four stroke, make sure you have a spark, take off the air cleaner and direct propane from an UNLIT torch into the throat. It helps to have someone assist in this usually. It has worked most of the time and usually when it gets running, it stays running.
If it has spark and compression, it should run on the propane.
/ Snapper rear engine rider. Dead.. #27
Did you check to see if it has a spark at the spark plug?
/ Snapper rear engine rider. Dead.. #29
It looks like lightning, just smaller.
Ha! I was looking closely at spark plug gap. Didn’t see it. Not getting a great pull left handed on the pull cord though. I’m thinking I should have or would have seen it, if it was there.
/ Snapper rear engine rider. Dead.. #31
Any ignition switch must be on, and the plug thread must be grounded. Often not that easy. A friend gave me a cheap spark tester that makes things quite a bit easier. But with the plug in, it does not spin as readily making a spark you can see.
/ Snapper rear engine rider. Dead.. #32
If you don't have spark, a new carb isn't going to help you. ;)
You can put a pair of vice grip pliers on the nut of the spark plug, then put an alligator clip lead on the pliers and then the other clip lead to ground. Then lay the pliers down so you can see the gap easier. The heavy vice grips keeps the spark plug from flying around when you yank the cord, and it's easier to see the gap with the plug laying on it's side. Hope that helps.
/ Snapper rear engine rider. Dead.. #33
You can get a spark plug tester at Harbor Freight for $4.99. Autozone for less than $10.
Thanks for the advice. I wasn’t testing it right. I’ll get a tester, or try vice grips. Can’t make any progress until I get the spark sorted out. I’m thinking of taking a small engine repair class as part of my retirement program. I’ve got zero patience. I was just looking at replacement engines.. :confused3:
I think the gas was down in the crankcase for a long time. There’s a fair amount of corrosion forming around the outside of the crankcase. Kind of a light colored seep. Wonder if that’s from the gas sitting in the crankcase for so long.
/ Snapper rear engine rider. Dead.. #35
Small engines like this are pretty simple. A class would be well worth the time spent. Once someone shows you how things work a couple times it's a piece of cake. And, even if it is sometimes not cost effective to repair something, it's a worthwhile task to repair something as it gives you a better understanding of how it works, and then a better understanding of how important preventative maintenance effects engine life and operation. It also helps with diagnosing future problems when you picture the moving machine in your head with all the parts interacting.
For example, I have a Poulan Pro 42cc chainsaw that I've used for about 10-11 years to cut all the wood to heat our house. It's a cheap saw. I bought it as a factory reconditioned saw for $99. I've cut 66 cords of wood with it for our house, plus a bunch of trees for friends and families. For $99. Can't beat it. Well, it started running strange. Turned out to be a cracked piece in the ignition coil. Ignition coil with shipping was something close to $50. For a $99 saw. I ordered it anyway, just to see if I could fix it. And I did. It probably wasn't a financially sensible thing to do spending half the cost of a 10-11 year old reconditioned saw that may not last another year or two, but $50 for an educational experience is money well spent. Cheaper than college credits, that's for sure! :laughing:
/ Snapper rear engine rider. Dead.. #36
I was once working on a Wisconsin Robins 7 HP engine...The coil was putting out so the plug was showing spark when testing but the engine would not run correctly...it kept back firing and running like the timing was off...it turned out the coil was faulty even though it was sparking the plug...it was an internal fault...
FWIW...Even with the learning experience above I still think the easiest way to test for spark is to remove the plug from the equation...just hold the wire and allow your hand or finger to contact the engine case...then just slowly turn the flywheel enough...if the coil is putting out you will feel it...then just use a new spark plug if it is in question...
/ Snapper rear engine rider. Dead.. #37
That was similar to my chainsaw issue. I had spark when testing it. Good spark. But when I'd run up the RPMS, it would start acting weird. Turns out the crack in the coil's foot would open with RPMs, and make good contact when the engine was out. The only reason I found it, was because I took the coil off, and the foot stayed on the engine when I lifted it off.
I can try this pretty quickly. I’m hoping I have a spark. There’s a community college a few miles from our house. I’ll see if they offer small engine repair.
I’m at the farm today. Put a new gas tank in my old craftsman lawn tractor and mowed most of the day. That thing has held up amazingly well. The Snapper looks brand new compared to it.
Not good news. I put it on the trickle charger all night. Battery looks good. Turned key to start, it still just clicks. Went back to “run” position on the key. Pulled the plug out. Pulled the cord a few times with a screwdriver down inside the plug cap. Nothing. I was ready to get my heart stopped, but nothing..
Did I do it correctly? Anything else? I guess I can go get a tester, but shouldn’t I have felt something. I was holding the shaft of the screwdriver.
I wonder if this wasn’t in a flood somewhere. I mean it’s brand new, but it’s dead..
Jeff
/ Snapper rear engine rider. Dead.. #40
No one around to help out? Me and many guys like me would like nothing better than to take the time to sort out yet another puzzle like this, and try and help someone out.
