snapper comet trans lube
   / snapper comet trans lube #1
james matt dillon
bluefield
snapper rear engine riding mower
Thank you for the chance to join your group! I am a new member with a question about what I can use in the transmission of my old snapper comet riding mower? SNAPPER AND OREGON wants a small fortune for their 00 semi grease is there a substitute for that use to use 80/90 gear oil they say that will run out of the plugs but mine as lasted 40 years and is still going I am currently rebuilding everything on it and a new paint job. Thanks again! JAMES MATT DILLON.
   / snapper comet trans lube #3
Welcome, 40 years using Snapper 00 grease? Prorate it is it worth the chance? Actually Snapper grease is not what it used to be with graphite in it. I get from Stens which is high but not as high as where you are talking.
Walt Conner
   / snapper comet trans lube #4
Welcome to the forum!
:welcome:
I'm going to move your thread over to the Snapper section in case you need some more answers.
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A53473)
2022 Gravely...
2013 FELLING  SKINNYNECK TA LOWBOY (A53843)
2013 FELLING...
U56 DIESEL FIRE PUMP (A51406)
U56 DIESEL FIRE...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A53473)
LIKE NEW 2023...
Valvoline 85/140 Gear Oil (A53117)
Valvoline 85/140...
2016 CAT 325FL CR (A47477)
2016 CAT 325FL CR...
