snap
swnoel
New Hampshire
Kioti DK35
That's the sound I heard while using my BH to plant some small trees...
I checked the arms and hoses out all appeared ok...
Started a second hole and... snap
This time the top arm stopped working...
Everything else appears to work except for the top piston.
Something must have let go inside the piston... Anyone else with this type of problem?
Bummer having to dig those holes by hand.
</font><font color="blue" class="small">( Something must have let go inside the piston... Anyone else with this type of problem ? )</font>
No, and I hope I never do !!
We are in the process of putting in a new house and I have a lot of backhoe work coming up digging for utility lines and lots of drainage.
One thing I do not need right now is messing around with a broken backhoe.
Hope you get fixed up quick.
Is your backhoe still under warrenty ?
/ snap
I hope so, it's less than 1 year old...
I'll find out Tuesday, I plan on calling my dealer with the bad news.
Sorry to hear about your problem swnoel. I've not had a problem like that at all. Did you see any hydro fluid at all? Sounds like maybe one of the piston arms broke. The BH should be under warranty for one year. Good luck and let us know what it is. John CK20 Albums
/ snap
No hydrofluid... no nothing
Just a loud snap!
/forums/images/graemlins/confused.gif
What dealer is going to get the good news?
Cpt.Dave
/ snap
I bought it from Central Tractor in Tilton.
Stanley has used me well.
After looking at the schematic of the BH and cylinder...
My guess is that the nut on the end of the cylinder shaft has pulled off...
Hope all the cylinders don't do the same....at least not after the warranty has expired.
SW, which backhoe model do you have? I have the KB2365 and so far, no problems except a small leak from an O ring that was deformed from over tightening. John
I had a 2385 rip off the nut inside the cylinders on the dipper stick. No leaks, no noise, no nothing. This machine belongs to an experanced hoe opperator. I replaced the cylinder for the man... that's the first one I have heard of having that problem..
/ snap
Looks like this maybe the second and I wasn't working her hard.
Hope this doesn't happen to the other cylinders /forums/images/graemlins/crazy.gif
</font><font color="blue" class="small">( Hope this doesn't happen to the other cylinders )</font>
Yes, I do too. Let's hope it was just a weak one. John
/ snap
Got back to the dealer today... as expected it was the nut on the end of the cylinder shaft.
He said it was probably due to backing into a tree or some other object.
May have been a tree, as if been working, removing stumps.
Never knew I hit one!
This is the second one that has done it to him.
Hope mine is the last for both of us.
2015 MACK PINNACLE DUMP TRUCK (A60736)
2015 MACK PINNACLE...
2006 International 7400 SFA Terex Hi-Ranger 6TC-65 65ft. Insulated Bucket Truck (A60352)
2006 International...
Electric Concrete Mixer (A61166)
Electric Concrete...
John Deere 6125R (A60462)
John Deere 6125R...
2020 CATERPILLAR 262D3 SKID STEER (A62129)
2020 CATERPILLAR...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
