Smoothing rough pasture w/deep wheel-ruts
   / Smoothing rough pasture w/deep wheel-ruts #21
Re:garden tractor vs compact
Richard,
I have NOT used the 4700 to mow a lawn. Heck I don't even have a lawn to mow! :cool:
BUT, one of my "hopes" is that my ground is hard enough so that I can use the 4700 with some sort of a 3PH finish mower on whatever lawn I end up with. I don't like to mow so I don't like grass. My house has lots of raised beds to cut down on mowing. I can mow my front and back yard in under 30 minutes and I have a decent size lot.
However I think the property we will build on will have more grass for a variety of reasons.
When I test drove the 4700 at the dealer I REALLY tried to tear up their grass. I had read about the MFWD scuffing problems so I tried the 4700 in 4WD and very tight turns. The tight turns would scuf up the grass abit. But I was really trying to do this and if it was my lawn I certainly would not have had MFWD engaged nor would I have to turn as tight as I was.
With normal turns and 2WD I did not scuff/tear their grass. The only thing that REALLY messed up the grass was buy moving forward at a good clip and then PowerReversing. I did not realize I should not be doing that kinda of direction change. And I ended up buying that tractor.... :cool:
The dealer has the same hard clay soil I have so I think the results will be the same. His ground was dry as well. From what I can see on the house site, if the dirt is reasonably dry I could mow with out tearing up the soil with the R1s. So I THINK I'll be able to mow the lawn.
I'll have to do more experiments once I'm living on the land and have a lawn before I spend the dollars to get the finish mower but I think it will work on my place. Its going to be very site specific and maybe grass specific.
Hope this helps. I hope someone who has tried this answers.....
Dan
   / Smoothing rough pasture w/deep wheel-ruts #22
Sounds like my place, Dan. I don't have a "lawn" but I have a big yard, so I'm mowing it with a 60 rear discharge finish mower behind my B2710 with Ag tires. Can't hurt it when it's dry, and what tracks I might leave if it's wet are not enough to worry about./w3tcompact/icons/laugh.gif
Bird
   / Smoothing rough pasture w/deep wheel-ruts #23
Hey Bird,
Does your finish mower cut grass as good as a lawn mower? I know darn well I want to use the 4700 to mow and not a lawn mower. My mower is on its last legs and I'm just hoping it lasts long enough to get to the property and find out that a finish mower will work. Then it can die. :cool:
Thanks...
Dan StuckAtWorkAndNOTHappyAboutIT McCarty
   / Smoothing rough pasture w/deep wheel-ruts #24
Dan, I'm using a Bush Hog RDTH60 finish mower and, yes, it mows as well as the 38" Cub Cadet riding mower I had before, and I liked the Cub Cadet. I guess you can get some windrowing with almost any mower, but this rear discharge mower doesn't windrow as much as the Cadet did because it was a right discharge.
Bird
   / Smoothing rough pasture w/deep wheel-ruts #25
I have no experience yet, since I just got the TC45D, but I sure plan to mow about a 5 acre yard with it and a 72" finish mower. I have been doing this with a Ford 4000 with ag tires. No problems as long as the ground isn't too soft. TC45D is about 1500# lighter than the 4000 and has R-4 tires that should be easier on the yard than the ag tires. Finish mower does a great job, with very little windrowing unless grass is real wet or real tall. I'm pleased.
Bill
   / Smoothing rough pasture w/deep wheel-ruts #26
I used to have about a 2 acre lawn but when I fenced the pastures I put most of it into pasture. I only have about a half acre of lawn now and lots of trees and landscaping. I can see if you didn't have trees landscaping, fences, etc. that it would work but I have to have my rider. Also it would be pretty hard to even turn mine around and there are alot of places I wouldn't even be able to touch with the tractor. I'd just keep those things in mind when you build your house Dan. I think if you planned for it you could probably do it with the tractor and mower. I think the price of a 6 foot finish mower is around $2500 and for my uses I'd rather have the rider and the tractor.
   / Smoothing rough pasture w/deep wheel-ruts #27
My 10hp, 42"-cut lawn mower died the same week I took delivery on my 790 w/turf tires (talk about "lucky", eh?). I'd never considered a JD lawn mower before, but after the experience with the 790, I headed right back to my JD dealer.
I was again extremely lucky; he'd just taken in on trade a 60" midmount deck from a 790! Normally $2,500, I got it one season old for $1,800. The reason for the low re-sale value is that these decks are pretty model-specific... long as I was going to take it off his hands, he was happy. I would not have considered mowing with such a big tractor normally, but the cost of the deck was about half the cost of the riders I was looking at. I was absolutely amazed at how nice the job turned out.
My rider had been a 4-wheel steer, but even so, the 790 was fine. No way I would want to use a 3PH finish mower. I have just enough maneuvering required that it would have been a real pain.
<font color=green>mark</font color=green>
Dan,
A friend built his "dream house" and needed a mower to cover his 10+ acre lawn (LAWN... not field!). He already had two JD riding lawn mowers, but didn't want to be perpetually mowing his lawn around the clock.
I helped him get a Befco Bat-Wing mower. First we ordered a 15', then some grounds people from a golf course recommended the 12' to reduce scalloping because of his rolling hills and man-made ponds.
He has a large compact <font color=red>Massey Ferguson 1165</font color=red><font color=green> (like a JD4600)</font color=green> pull this monster. All in all, about 6600 lbs rolling over his lawn... very impressive... very fast. Yes, it looks like a "golf course".
http://www.befco.com/products/cyclone/flex.html
   / Smoothing rough pasture w/deep wheel-ruts #30
The Kubota diesel will last more than twice as long as a gas engine if maintained properly. Have had Honda, JD, Sears......nothing compares to the life I've seen from Kubota diesels around here. 1/2A garden is not small. If you plan to work it every year you will be thankful you got a compact. Just like the compact tractor the implements will have multiples of life compared to those of a garden tractor (haven't seen garden tractor ones that I would even consider buying). Plus, a lot of good used compact implements are out there, just have to look and wait: Got a 36" old Howard tiller and a 5' hog for $250 last summer--right place at the right time......
Resale % of Kubota compacts are far higher than any gas units I've seen as well. Good luck.
30in Forks and Frame Mini Skid Steer Attachment (A56857)
30in Forks and...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2012 Chevrolet Impala Sedan (A54815)
2012 Chevrolet...
2015 Toro Reelmaster 5510D Fairway Commercial Reel Mower (A56857)
2015 Toro...
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
Schulte SBW800 Rock Windrower (A56435)
Schulte SBW800...
