Smoothing out yard
   / Smoothing out yard #1
BXmark
Bronze Member
BX2200
My new 2 acre front lawn is a former hay field. It is so rough from being plowed and from the clumps of Timothy hay still growing that it is like cutting on a washboard. Any recommendations on how to smooth it out? My neighbor tried rolling his with a HUGE roller and it made little difference.
   / Smoothing out yard #2
I had a similar problem with the property we bought. I ended up pulling a disc first in the direction of the furrows then with a lighter cut at a 45. I should have made one more pass perpendicular to the last one as there are still some bumps. At least now we can mow in any direction where before it was nearly impossible to travel across the furrows /w3tcompact/icons/smile.gif
   / Smoothing out yard #3
Kill the Timothy out with Round Up,disk,till or work the ground some how,drag it with a harrow or bed springs,seed it and hope for the best.I've tried everything under the sun to smooth out rough ground and this is to "my" notion the only way.
   / Smoothing out yard #4
MReeter is right. If you really want smooth ground the only real way to do it is to start over.
   / Smoothing out yard #5
Have a tiller?
Bluegrass, Pick It Up!
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A53473)
2014 Doyle Dry...
2015 Ram 3500 Crew Cab Truck (A52384)
2015 Ram 3500 Crew...
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
2017 KENWORTH T680 TANDEM AXLE SLEEPER (A53426)
2017 KENWORTH T680...
2016 Case CX160D Hydraulic Excavator (A51691)
2016 Case CX160D...
