Smoothing out my yard
/ Smoothing out my yard #1
RollTideRam
Veteran Member
Hartselle, Alabama
Kioti DK 4710 Cab
I am wanting to buy a tiller, but not sure if I really need one. I have about a three acre yard with some rough spots and some terrace rows I want to smooth out. My yard used to be a cotton field then a pasture. The first hill I have started working on runs the length of my yard. I have run the box blade with scarifiers down and used the subsoiler to break it up. It is in very large chunks because we are so dry. I could borrow a disk or buy a tiller. Witch would work better? Thanks, JC
/ Smoothing out my yard #2
either will work
tiller is probably better
get a chain harrow to smooth it back out.
/ Smoothing out my yard #4
It's bone dry here every year. I use my ranch truck with over-inflated tires to smash the clods. Works great. Tires with chains would work even better.
I decided to borrow the disk instead of buying the tiller. I need to make sure I will use the tiller enough to fork out money on it. JC
213097 (A64276)
213097 (A64276)
2023 KOMATSU D61PXI-24 CRAWLER DOZER (A65056)
2023 KOMATSU...
2008 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2008 FORD F150...
2004 Johnson 40hp 4-Stroke Outboard Boat Motor (A66738)
2004 Johnson 40hp...
(2) 15.0/55-17 TIRES W/ 6 LUG RIMS (A64280)
(2) 15.0/55-17...
2003 NOBLE 12000 GALLON WATER TOWER TRAILER (A65054)
2003 NOBLE 12000...
