Smoothing a Field of Grass
   / Smoothing a Field of Grass
slopecarver, I have no desire to own a flail mower. Way too many pieces parts to maintain for my liking. That stone burier does a hellofajob! Just looks like a tiller with different type rollers to go behind it.
searcyfarms, My little 855 is a 2WD with mud grips on the back. I can stall it with a full load in the grader blade or landscape rake. I don't think it would try to pull a box blade. One of these days I hope to upgrade to a 50ish HP 4WD.
   / Smoothing a Field of Grass #12
I have levelled multiple food plots. Install eyebolts on both ends of a railroad tie. Run a chain from each eyebolt to a disk harrow (two separate chains). Make sure you use enough chain so the tie is being pulled horizontally across the ground. A short chain will pull the tie up. Disking slow so your tie doesn't bounce. Make you second pass at 30 degrees.
   / Smoothing a Field of Grass #13
I know this is an old thread, but thanks for the excellent tips, guys! It's good to learn new things in forums like this. Especially since I recently installed my artificial grass with It's Artificial Grass | Suppliers & Installers of Artificial Lawns | Astro Turf, and now my life is so much easier. Honestly, my garden looks so much more attractive than when there was natural grass. Now I don't need to use my lawnmower to take care of the natural grass, but still, some actions need to be taken to make the grass look good, but otherwise, I'm delighted. I suggest you try installing it sometime too.
That Artificial Grass stuff looks fakey as all getout!!!
I bought a tiller to work the land over and built a homemade drag to smooth it out. Grass seems to just pop up natural without planting on my land so I guess I'm lucky.
Mowing is much smoother since this thread originated.
   / Smoothing a Field of Grass #15
Sounds like a SPAM post to me... :(
I agree but I checked his other posts and he seemed to be on topic without repeating the fake grass plug.
2015 TROXEL 130BBL KILL TRAILER (A53843)
2015 TROXEL 130BBL...
Cushman Cart (A55853)
1995 Koehring LRT-110 7.5 Ton 4WD Rough Terrain Crane Truck (A55787)
1995 Koehring...
2014 MACK GU713 WATER TRUCK (A54756)
2014 MACK GU713...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
