Smoking Massey 35
   / Smoking Massey 35 #1
Houlio45
I've got a Massey 35 (3 cylinder) that is hard to start, bogs down easily and exhaust huge amounts of black smoke. From what I've been able to glean in research, this is likely and fuel/air issue.
I changed both fuel filters, removed and had tested the injectors, one turned out to be faulty. Still bogging down and black smoke.
I removed the complete air cleaner and ran the tractor for about an hour. Really did not notice a difference in smoke, however, I did notice that where the rubber hose to the cleaner would normally be attached to the engine (next to the preheat starter element), that there was an exhaust coming from there and that when the engine would bog down (as it often does) I could see combustion (flames), almost like looking into a furnace. Is this normal?
If it is indeed a fuel/air issue, is it perhaps the fuel pump?
Any advice thoughts are much appreciated.
   / Smoking Massey 35 #2
Do a compression test for bad valves and check timing.
   / Smoking Massey 35 #3
It is more than likely the Thermostart in the inlet manifold that has failed, when they go bad they will leak a constant dribble of fuel into the manifold, pick up and install a new one, should fix the problem
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2013 Club Car Carryall 252 Electric Utility Cart (A51691)
2013 Club Car...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A53472)
2015 RAM 5500...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
