Smoking Iseki
   / Smoking Iseki
The rear cylinder's injector had a greasy look to it that reminded me of a spark plug that's in an oily cylinder. The front injector looked clean. I didn't see any obvious pitting on either injector.
I really enjoy this website, and the knowledge that people here have is a great asset. If the weather's not too bad this weekend (unheated garage) I may try to do a little checking.
Thanks,
Jeff
   / Smoking Iseki #12
If you have no crankcase pressure then you have minimal blowbly which means your rings are fine. Now do a compression check.
Caterpillar 906M (A53317)
Caterpillar 906M...
Toro Groundsmaster 4000D (A56857)
Toro Groundsmaster...
1995 Koehring LRT-110 7.5 Ton 4WD Rough Terrain Crane Truck (A55787)
1995 Koehring...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
Electric Sweeper W/Pressure Washer, Water Hose, & Mister (New/Unused) (A59225)
Electric Sweeper...
2015 FREIGHTLINER CORONADO 122 SD (A58214)
2015 FREIGHTLINER...
