scott_vt
Super Member
- Joined
- Oct 5, 2004
- Messages
- 8,069
- Location
- east wells,vt
- Tractor
- 1986 MF 1040, 1942 Farmall A, 1949 Farmall Super A
Bird said:Scotty, that sounds good, but in this part of the country, I'm not sure we'd even have to light the first to smoke stuff today. Ninety-six degrees that last time I looked out.![]()
tallyho8 said:Scotty,
For those of us who are BBQ-challenged, it's almost torture to have to sit here and look at those photos and drool.![]()
Wil said:Oh Jim & Bird that was Cool we got up to 113 here in Yuma.
Now that is HOT.
Now that is HOT.
Hi Jim, honey and mustard sounds like a glaze I use the last hour of smoking ham. Just mix up ï½ cup honey, ï½ cup of pineapple juice, 1 teaspoon of dry mustard and a bit of cloves. Brush on a few times during the last hour and it leaves a nice honey glaze on the meat.jinman said:Has anyone ever heard of using mustard and honey as a baste? ...or a rub, maybe? I had some wild turkey smoked with that as one ingredient and it tasted terrific. I think the other ingredients were more traditional. I don't know how much the guy used or when he basted the turkey, but the end result was very good.
MarkV said:You smokers that like ham may want to try something we have been doing that is received well. Take your normal 6 lbs. ready to eat smoked ham from the store. Cover with your favorite rub, foil it and let it sit in the frig over night. Mix a baste of ? cup chicken stock, ? cup pineapple juice, 1 ス tablespoons of veggie oil, 1 teaspoon of dry mustard and ? teaspoon of cloves. Heat on the stove until well mixed. Smoke the ham for 6 hours between 200 and 225 degrees basting once an hour. The last hour baste several times with the glaze outlined in the first paragraph.
Smoking the precooked ham really adds to the flavor and tenderness. It will feed a good number of people at a reasonable cost and leave you some great left over's for sandwiches.
MarkV
jinman said:Scotty: That meat looks terrific. My neighbor smokes barbecue every year around July 4th and I'm starting to get anxious already. His ribs are the best I've ever put in my mouth.
Brinkman does make another smoker that has three pieces, the lid, the main body and the firebowl. With this unit you can lift the main body up and add coals to the fire without trying to get them through the little door. I think they call it the deluxe model or something similar. I have found it much easier to work with, especially when smoking the larger meats.Nasty135 said:Hi Scotty, I found a SS smoker built just like yours, and found out that my first effort should not be an 18lb. turkey....Talk about an all day deal...
The wife always says go big or go home: Heck! I am home![]()
Here is some of what I learned:
1. Load that sucker with as much charcoal as it will possibly hold
2. Soak your chips as you have indicated
3. you can fill the upper bowl with wine, onions or other flavor enhancing items
4. Watch your heat indicator and walk away
5. go build something...![]()
Problem issues I have had, Item your cooking is going to take awhile ie: Turkey ...Problem is you add charcoal through the little door ,which is a pain. I ended up using a huge metal spoon of some sort to place coals where I wanted them...secondly , this will be a good modification for you to patent...When my bottom coal pan is finally dying down and the ash is already deep it kinda smothers its to where the heat is way down, so I think it needs some kind of raised coal grille so the ash can fall through to the bottom of the pan to keep the coals kick'n out the heat... Maybe yours has this mine was bought second hand at a yard sale...
and I haven't done much about it yet...
I thought about using my leaf blower to blow the ash away from the pan exposing the hot coals but I don't think anybody would want to eat the meat after that...![]()
But anyhow we have successfully smoked goose, & turkey although the turkey ended up a little dry from taking so long, it still had good smoked flavor...Once you get the hang of it...Let us know how it went...![]()
