Dave, that's the same smoker as the
Masterbuilt Smoker. That was my first smoker and I loved it, but after about three years of sitting out in the weather, the heating element quit working. I haven't ever checked to see what is wrong with it because my darling wife bought me another one that is larger, stainless steel, and has glass in the door so I can look in and see what is going on without opening the door. I like the Masterbuilt smokers a lot, but there are some things you will want to do that are different with them and a traditional wood smoker.
The wood chip drawer is a big plus, but I've found I prefer to add dry chips rather than water soaked chips. When you are smoking on low heat, adding additional water soaked chips can extinguish your smoldering chips and then the heating coils don't stay on long enough to get the chips going again. When you are smoking at 200 to 225 degrees and the smoker is up to heat, it doesn't take much heat from the coils to maintain that temperature and it's not enough to get the chips going. Therefore, the smoke is reduced dramatically. I actually make it a practice to use dry chips and then open the big door every hour to baste the meat. I leave the door open until the inside temperature drops to 150 or lower. That way when I close the door and add chips, there will be a full heavy smoke cycle as the heater brings the smoker back up to full temperature.
With that smoker, you won't have to worry about the outside of your meat turning black from smoke tar as in a traditional smoker. You can leave meat in the smoker for 6 hours or longer and it will not have to be wrapped to keep it from turning black like some smokers. Your meat will have a dark coating, but not the heavy black tar you see in regular smokers. I find ribs are tender and delicious after 5 hours at 200 degrees. If you then raise the temperature to 225 or 250 for an addtional hour, the ribs will fall off the bone and be delicious. I've done one brisket, but those take a long time at low heat, maybe up to 10-12 hours, to be fully cooked and tender. I prefer to do pork, ribs, chicken, and ham. Those are all easily cooked in 4 to 6 hours.
I think you'll love your smoker and even cleaning isnt' too bad if your line your water pan with heavy foil before adding water/wine/beer. If you have a big container to soak the racks in soapy water, they come clean easily. Of course the inside of the smoker becomes very seasoned and nasty looking, but that's just the nature of a smoker. Run it up to 250 for an hour before smoking to sterilize the smoker and there will be no worries. Let us know how it turns out.
I've added some photos of my smoker in use. The first is with a brisket and ribs before smoking and the second is when I took the ribs out and kept smoking the brisket for a few more hours. They were all delicious.:licking:
