Smoked a JD 4110 60' deck gear box
   / Smoked a JD 4110 60' deck gear box #1
oscer
Central Pa.
JD 4110
Hi fellas, the lower bearing and seal went out on my mower deck gear box. After tearing it all apart and finding blue gears and wasted bearings I find out Deere doesn't break it down into parts but wants to sell the whole gear box for $653.xx. Any one know where or how to find new gears for it? the bearings should be pretty easy to match up.
   / Smoked a JD 4110 60' deck gear box #2
Something like baler twine or wire wrap up around the spindle?
   / Smoked a JD 4110 60' deck gear box #3
I doubt JD made the gear box. I would be looking for any indentifying marks and try Google. Good luck.
Kim
   / Smoked a JD 4110 60' deck gear box #4
464.00 on ebay
peerless Co make gear boxes for jd
   / Smoked a JD 4110 60' deck gear box #5
Just put in the bearings if the gear teeth arent worn. Use corn head grease instead of gear oil.
   / Smoked a JD 4110 60' deck gear box #6
I got the seals for a gearbox on my 60 that I had on my 855. Did you look it up on jdparts, or did you call the stealership. I've found that they can get parts for things that aren't normally broken down on jdparts. Maybe the parts are discontinued now too. It's been a while since I put the seals in, I traded mowers a couple years ago.
No the lower seal just went out and left it run dry. I didn't even hear a warning sign, just bogged down and it was all over.
464.00 on ebay
Thanks for the reply,I'll check it out. Gear box says made in Spain.
SPYDERLK, the gears are worn and blue on the wear surfaces. $464 on ebay may be the way yo go.
   / Smoked a JD 4110 60' deck gear box #10
I purchased a complete 60" deck for $15.00. How many gear boxes are the same? I bet many are the same placed in off set locations. At dealer values its worth a try.
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
2002 International 4300 Truck, VIN # 1HTMMAAN92H547720 (A51572)
2002 International...
2023 CATERPILLAR 259D3 SKID STEER (A51246)
2023 CATERPILLAR...
2003 Maverick Pathfinder 2200V Center Console Fishing Boat with T/A Boat Trailer (A50324)
2003 Maverick...
2015 Kia Sorento AWD SUV (A50324)
2015 Kia Sorento...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
