Smell hydraulic fluid?
/ Smell hydraulic fluid? #1
Anonymous Poster
Epic Contributor
Occassionally, after long periods of use (read 2+ hours) , I start to smell hydraulic fluid. I don't see any leaks anywhere and my "dipstick" shows the fluid is still full. Is this normal? I didn't start to notice it until I put on my FEL. The temperature on the gauge is normal (towards cold).
BTW, here are the specifics about my tractor. 2710, FEL mounted, box blade on rear.
Any ideas, tips, concerns???
Thanks,
greg
/ Smell hydraulic fluid? #2
Hello Greg,
I get the same thing with my B2400. No leaks, just a little stinky when it's hot. So far, my guess is the smell/vapor is coming from the vent tubes in the transmission case under the seat.
/ Smell hydraulic fluid? #3
You might want to check the tempereature of the oil. You don't have to be to precise but is it hot to the touch? Transmission oil often runs up to 200 degrees so watch out but just pull the dipstick and get a feel for it. As with all oils they get thin as they get warm and you may have a leak that only occurs with the oils being warm.
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
Frac Manifold S/A Trailer (A64194)
Frac Manifold S/A...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
2019 JOHN DEERE 331G SKID STEER (A65053)
2019 JOHN DEERE...
2022 EZ-GO ELITE...
